Old 14-07-2006, 01:28 AM   #1
hmc 'mont
ELMONTY
hmc 'mont's Avatar
Question Faded headlights
i was just wondering if there was any way to fix this problem of the fading and yellowing on ef/el headlights. I have had some cutting compound on them which works sort of but not good enough. Is there an easier way? or should i just buy new lights???
thanks.
hmc 'mont is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 09:27 AM   #2
Kenaz
Kenaz's Avatar
I tried polishing mine, but they turned out pretty crap so I just bought some new ones.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 10:02 AM   #3
bailey04
RockGod
bailey04's Avatar
There is a tech doc on Ford Mods that tells you how to do it..
Basically you sand the headlight back with about 4 or 5 different grades of sand paper and then polish it..
I did it about two weeks ago and it worked a treat. Made the headlight clear and removed the yellowness..
bailey04 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 08:54 PM   #4
hmc 'mont
ELMONTY
hmc 'mont's Avatar
awsom
cheers for your help
Old 14-07-2006, 08:57 PM   #5
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
a while ago some1 on here said they took the light apart and swished some CLR in the light, dryed it out with a hair dryer and they were brilliant. havent had to worry about it myself.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 09:01 PM   #6
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
If you do get newies, just polish them every couple of months. They will stay pristine that way.
Jeeepers is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 09:25 PM   #7
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Autobarn used to sell a PLASTIC POLISH. It worked awesome. We used it on a friends Lexus/soarer and the lights came up great. Heaps of elbow grease but worth it in the end. We did it 4-5 times to get good results.
I think it may have been a MEGUIARS product ?? $20 off memory
Old RIDE
2006 BFGT
Gone but not forgotten
New RIDE
2018 AMG Mercedes A45
Angry AWD assassin
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 09:45 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Autosol Metal Polish
It has little grains in it that helps with the polishing - eg like sanding
Doesnt matter what you do to them though policsh or sand or both they wont ever be clear again unless you replace them with new ones
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 09:57 PM   #9
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Try this :
http://www.meguiars.com.au/product_2...lastics&show=3
Old RIDE
2006 BFGT
New RIDE
Angry AWD assassin
Old 15-07-2006, 02:08 AM   #10
feebs
BrwnBstd
feebs's Avatar
If you use a scourer then you bugger the lights, you can use a light acid to clean them up.
Phosphoric acid or similar, wet the paint b4 and after tho, maybe take the lights out.
feebs is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 01:20 PM   #11
peterban
AULTD
peterban's Avatar
Here is the link to the how to article.
http://www.fordmods.com/forums/documents.php?doc=58
I did it to my son's ef fairmont.
When I started you could't see any of the lines in the plastic as they were so yellow.
They came up to about 95% perfect.
I just polish them now with plastic cleaner and have had no more problems with them.
Note that even clean the low beams are still woefull, but I think that is a common complaint
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 01:28 PM   #12
LUXO_8
windsor user
what happens is not only does the lens go off....but often the chrome on the reflector goes off as well.......
my parents EL had new lights in it and i thought the lights were quite good..
the fact that fairmonts have a H4 globe (dual filament) which should be even better again than a falcon (H1 single filament) leads me to believe the reflectors might not be in the best condition in your sons car...
Old 15-07-2006, 01:56 PM   #13
JUZXR8
Hmmmmm
JUZXR8's Avatar
my EA FALCON runs H4 globes as standard..........
i ended up sanding back the ones on dad's monty, then gave em a polish up and they came out a treat
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 01:58 PM   #14
LUXO_8
windsor user
yes i know that.... ea-ed have nothing to do with this.....
i was talking about EF and EL...which happen to also only be the ones with PLASTIC LENSES
EF and EL Falcon have H1 and H3 globes, while EF and EL Fairmont/Ghia, Fairlane and LTD have H4 and H3 globes
Old 15-07-2006, 03:21 PM   #15
mons2b
Smile
Better if they went back to glass headlights then. Please Ford. :-)
EFII Futura in green. Got to be :voldar02: good for you.
mons2b is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 03:25 PM   #16
LUXO_8
windsor user
will never happen......
plastic doesnt break anywhere near as easily as glass does...it has flex...resulting in less danger in accidents
if they go yellow it can be fixed.....
there are a lot of reasons why plastic lenses are SO much better than glass lenses....
where a glass lens would break...the plastic lens might just scratch....which can then be polished out for a very small cost...
Old 15-07-2006, 04:00 PM   #17
Fairlane
V8 Powaah
Fairlane's Avatar
Man can we make a yellow headlight thread a sticky.
No offence to the people suffering from yellow headlights, but im sick of seeing these threads
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 07:14 PM   #18
private9
www.TUFFCARPARTS.com
private9's Avatar
If you're sick of seeing these threads it's pretty simple, just don't read it!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 07:32 PM   #19
LUXO_8
windsor user
the point was that this topic has been covered numerous times and if people could be bothered searching, or if there was a sticky thread, there wouldnt be multiple threads on the same topic
Old 15-07-2006, 07:36 PM   #20
private9
private9's Avatar
Fair call :
