any one know much about amps? last night on the cruise my amp for my speakers was cutting out giving me no music, but the sub amp was still working, john and hppsc forgotten his name said it would be they are getting to hot, so today i cut two 2 3/4" holes in the perspex went fine for a bit now its starting goign to protection again? anyone got any ideas of what it could be?
GOT 20'Z?
check speaker polarity and earth turn the gain down a bit
one day my car will live upto its plates! ![]() |
Check for shorting of speaker cable. Your amp may be stuffed as well.
Does Steve have a car?
I'd say check your RCA's first...
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
ORSM FORD CRUSIERS
not a good enought earth can cause that and also the check the rca's
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#6 | |||
now EFXR65spd
When mine did it it was because the gain was too high, causing the amp to overheat
Aspiring mr efxr
check nothing is shorting out (earth, speaker wire, remote wire, power) if it all fine try turning the gain down and the level down. still not working, new amp me thinks...
EDIT: could try relocation to better ventelated area too....
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
