Old 19-05-2007, 07:16 AM   #1
Rebel
Rebel's Avatar
Default Pinging
Just bought a XR8 Rebel 220 with 98k on the clock. When giving it WTF it makes a noise like pinging. In other threads, others make mention o2 sensors, dirty injectors, AF sensors etc.
Can any of these cause pinging? Any other suggestions!
2008 FG GT 315 EGO #460
1968 Falcon Sports Coupe **2012 PCOTY winner**
https://www.fordforums.com.au/showthread.php?t=11325000
1990 XF Falcon Panelvan
Rebel is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 08:50 AM   #2
RG
Back to Le Frenchy
RG's Avatar
Another one, whatever you do as long as it is pinging DO NOT give it to it. You will kill your engine, I know as I did. It could be a wide variety of things but first I'd be checking Fuel (Some 220's will only run on 98ron), Fuel filter and then oxygen sensors. Just don't drive the car unless it's you really need to or it could cost you big $$$. On the upside if you do drive it and kill the engine it's a great excuse to go a stroker...
Old 19-05-2007, 08:51 AM   #3
StealthAu
bad fuel, you should be running it on at least premium ulp, drain the tank, or add an octane booster
Old 19-05-2007, 10:57 AM   #4
DJM83
Barra Turbo > V8
DJM83's Avatar
Was gonna suggest fuel. What fuel are you running i ran normal ulp and it pinged its head off now run 95 or 98 and its fine
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 01:15 PM   #5
AUXRVIII
Grab a can of CRC CO contact cleaner (electrical parts cleaner) remove the airflow meter and give it a good spray. Dirt build up on the airflow meter will be a given and the engine doesn't get the full amount of fuel injected for the volume of air entering.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 03:42 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
mmm..I always keep a bottle of octane boost in my boot for mine, it rattles at the first sign of fuel less than 98 ron .. and has done sice new (side note :: I wont use Optimax either it has to much Variation from servo to servo : )
Originally Posted by Riksta
Old 19-05-2007, 03:51 PM   #7
Andy XR8
AU3 Winged Windsor
Andy XR8's Avatar
mine was pinging for a while and i have never put less than 95 ron in my car, so i took it in to ford, they said they gave the throttle body a clean and re-programmed the ecu and it went away.
Andy XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 04:59 PM   #8
howesy
howesy's Avatar
Spark plugs can also be an issue in odd circunstances
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 03:34 PM   #9
Rebel
Rebel's Avatar
I should have stayed with my XR6T. Besides my personal reasons for selling it, I was sick of it being temprementle. Hot weather loss of power, run like a pig if you got some slightly off fuel, pinging due to above reasons. Least when it wasn't suffering from the above, it went it like a dog with a backside full of rock salt! I thought being the old trusty Windsor all this crap would be gone. Boy am I a misguided SOB! :togo:
Old 20-05-2007, 04:17 PM   #10
fordAU
In my opinion you are correct, I find the 220's very temperamental, moody actually if that makes sense.
They are a demanding car with bad manners, especially manuals but I like them, gives a car character I guess, also as recommended above, probably safe to stick with 98ron.
fordAU is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 06:18 PM   #11
Rebel
Rebel's Avatar
Very good description!!!!!!! Mine is a manual also. I have only ever ran Ultimate 98, but some here don't like that either. Vortex 98 seems to be well respected, but limited outlets here in Newcastle.
Old 20-05-2007, 06:58 PM   #12
fordAU
Can't comment on Ultimate Rebel as I never use it, tend to stick with either Vortex 98 or Shell 98, no probs so far with either.
Hope the pinging sorts it self out and you get to enjoy your vehicle, they despite their idiosyncrasies are a great ride imo, not as refined like your T was but a lot of fun, very old school in some ways, my windsor and me are still :
Old 21-05-2007, 09:18 PM   #13
Sleeperau
Highway Taxi
Angry
I share your pain! Mine is an I6 which is supposed to have a knock sensor to eliminate the problem. (apparently). It does run better on 98 octane as nothing under 95 has ever gone in. It is not plugs or filter in my car & engine compression is the same. I hope this thread finds the solution!
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 09:28 PM   #14
crusher
Dirty ute club member
crusher's Avatar
When giving it what the ******? Pretty sure thats spose to be WOT right?
As most have said its probably just bad fuel or something. Hopefully nothing happens because of it!
2000 AU2 XLS Daily
1992 Toyota Celsior: 4ltr quad cam goodness
UZN106 Hilux: Absolute mongrel bitsa also with 4ltr quad cam goodness...Forced induction in the planning
crusher is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2007, 05:56 PM   #15
Andy XR8
AU3 Winged Windsor
Andy XR8's Avatar
unfortunately mine has started pinging again, i had a look at my air filter and its dirty as, i'll clean it, as it is a bmc filter and it looks quite dry, along with my throttle body, as it is pretty dirty as well, and hopefully it goes away before the weekend as i'm supposed to be draging it at the aff day.
Old 23-05-2007, 12:05 AM   #16
AUTickford
XD197
AUTickford's Avatar
Nup i think he meant wot the **** :
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 12:17 AM   #17
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
ive had mine for well over 18 months now and have only had it ping once. the reason for this was as nearly everyone has said bad fuel! the wife takes ot to work and it comes back running like @#$! but it has a full tank of fuel. she put normal ulp like what she runs in her series 1. No need to worry she promises never to do it again!
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 12:08 PM   #18
Sundeep
Sundeep's Avatar
My old EB 5L used to ping, had a freshly built motor and pooload of other new bits and pieces. Only solution was to back the timing off a couple of degrees.
Then I sold that and got a EL 5L, same problem :( After doing numerous things here and there I ended up changing the MAF sensor recently and it's gone now.
Just take it to Ford and get 'em to put the Code checker thingo on it.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 05:57 PM   #19
JC
JC's Avatar
Why not get an edit so it runs on ULP? Will only cost you around $1600 for a custom tune, and at 10c per litre cheaper, it will only take you 16000litres, or roughly 100,000km to make that money back, but it will save your engine from premature detonation.
Ford Performance Club ACT
Old 29-05-2007, 05:46 PM   #20
Rebel
Rebel's Avatar
I've had Ford service look at it, and they say it is not pinging. They say it is too rythmic. They are confident it is lifters and that I should run a engine flush in the oil, than change the oil and filter. After about 1,000k's change oil and filter again. They are also recommending 10w30 oil. Do you guys agree?
Old 02-06-2007, 07:00 AM   #21
Rebel
Rebel's Avatar
I've just had an independant mechanic look at this noisey, and he is saying it wont be a lifter. Sticky lifters etc are generally noisey at start-up or idle not at high rpm.
He is saying that it is the timing chain! It has done 99,000k's. Does the timing chains in these have any issues?
Old 02-06-2007, 03:31 PM   #22
RG
Back to Le Frenchy
RG's Avatar
Never heard of a timing chain having issues in one of these, after 40 odd years you'd think Ford would have ironed out an issue like that. 10w/30 oil sounds too light, I use Nulon 15w/50 fully synthetic and it's good stuff. What area do you live in?
Old 02-06-2007, 05:18 PM   #23
Rebel
Rebel's Avatar
Newcastle, NSW
Old 02-06-2007, 05:25 PM   #24
burnz
VFII SS UTE
burnz's Avatar
this is the most common cause ^^^^
2nd most common cause is water in fuel (500ml of metho will fix)
bad 02sensor should throw an error code
GO SOUTHS
Old 02-06-2007, 07:06 PM   #25
XEESP_351
Its not the stupid purge control solenoid u can hear ticking is it??
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:17 AM   #26
nikos
mezzo forte
While talking about pinging - the I6 is meant to have sensors that stop pinging right? Cos when I go up hills sometimes, and when I accelerate as hard as possible without making the auto drop down, I get a sound thats worryingly similar to pinging. Maybe its just something loose in the engine bay rattling?
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 07:08 PM   #27
T2TL50
Proud Owner of a T 2TL50.
T2TL50's Avatar
I know this is kinda stoopid!!! but how does one tell for sure it is pining?
The tl makes what i call the throttle body rattle or something to that effect when i am taking off HARD!!! and i am over it..
Only happened since G&D have tuned it?
Help?
One Of Fords Finest Cars!
The T2 TL50!! Maybe You Will Own One, One Day!!
T2TL50 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 07:25 PM   #28
philstoj
philstoj's Avatar
Help?
Best you take it back there and while its making that sound DONT thrash it, get them to check it out.
Old 06-06-2007, 07:52 PM   #29
Sleeperau
Highway Taxi
...Or your knock sensor is cactus like mine
Old 07-06-2007, 08:00 PM   #30
T2TL50
T2TL50's Avatar
the v8 dont have a knock sensor....
only the I6
