Old 30-05-2007, 07:57 PM   #1
EBIIXR6
EBIIXR6's Avatar
Default 3" exhaust for E series
the guy who fitted my Redback exhaust said that there is an "off the shelf" 3 inch Tailpipe i.e over the diff and out the back.
Does anyone know if anyone makes this?
Do redback make it?
93' EB II XR6 factory manual
Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02:
EBIIXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 08:21 PM   #2
STK-XR8
STK-XR8's Avatar
try Di Filippo in victoria, i just got mine done last week on my ef xr8, paceys twin 2 1/2" into single 3" ,single muffler & stock cats for now ,sounds deep not overly loud
http://www.darrendifilippo.com.au/
STK-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 08:37 PM   #3
BI6TIM
SnortPerformance.com
Yes Redback makes it. It is listed for the V8's
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 08:55 PM   #4
EBIIXR6
EBIIXR6's Avatar
thanx bi6tim.. do you know if it would fit to a 6cyl 2.5inch redback system? or is the join in a different location for the V8?
Old 30-05-2007, 08:59 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Lukey do a 3inch single from muffler back also
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 30-05-2007, 09:23 PM   #6
SVT8
SVT8's Avatar
yes lukey do make 3 inch systems. Im aware that lukey do a system for the V8's running a 2.5inch mandrel bent system leading into a single 3inch. Its something around the $500 mark though.
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 09:27 PM   #7
bentles
bentles's Avatar
unless you are forced why bother? and even if you are forced a custom jobby should be best anyway. 3" on a na 6 would sound terrible
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 09:29 PM   #8
dave.747
dave.747's Avatar
What makes a custom 3 inch tailpipe better than an off the shelf one? Seriously how can that be?
dave.747 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 09:33 PM   #9
bentles
bentles's Avatar
well if its just the tail pipe then theres no difference but if you are doing a turbo conversion it would be a full system anyway. im guessing hes wanting to put a 3" on a na 6 which is entirely his choice, just theres no point in doing it as it wont make it sound better and it wont make it perform better judging by his sig which doesnt list a very large amount of mods
Old 30-05-2007, 09:34 PM   #10
SVT8
SVT8's Avatar
not if you get the right combination of mufflers, cats and reso. It can sound pretty tough if done right, would be a very deep note though. But on a stock 6cyl, i would suggest that backpressure would be an issue?
Old 30-05-2007, 10:03 PM   #11
Steady ED
Steady ED's Avatar
Custom sounds cooler, also adds value and reduces ETs. Proven.
You'll be able to use the rear section of the V8 exhaust, will have to get something made up to meet your cat but.
Tail pipe is the hardest bit to get made anyway, from cat to tailpipe is a piece of ****.
Steady ED is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 10:13 PM   #12
sphell
sphell's Avatar
'custom' is bullshit unless the guy making it has done it before, tried the combo on the dyno and proved it to be good. Otherwise it's just gonna be a whatever fits and doesn't hang too low scenario.
I'd rather off the shelf anyday. At least you know they've done their R&D. Plus it'll all bolt up 100% and probably be legal too.
Old 30-05-2007, 10:16 PM   #13
OED666
OED666's Avatar
Redback do sell off the shelf 3" tailpipes. I have one lying next to my car as I type.
I am not sure if lukey sell a complete 3" system, as I enquired about this a short time ago. They do the 3" tailpipe though.
I am getting the rest of my exhaust made up soon. I am buying 3m of 3" pipe, 2 x 45 degree bends, and 1 x 90 degree bend, and 6, 2 bolt 10mm thick flanges. I am going with 1 muffler at the moment, the size is 10"x5". I am sure its going to be loud, if its annoying then I will see if I can get a muffler in the tailpipe.
Rollin had a 3" exhaust on his current ED that he recently purchased. It still went pretty well, and would keep up with his N/A EB XR6. Both were autos.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2007, 08:03 PM   #14
EBIIXR6
EBIIXR6's Avatar
Stop guessing mate...
i have modified the 2.5inch tailpipe with about 600mm of 3.5" exhaust from the exit and it sounds really good..
i wanted to know who does the 3" tailpipe because im turbo charging soon.
Is the 3" lukey/ Redback tailpipe $500!? shytza
Old 31-05-2007, 09:26 PM   #15
OED666
OED666's Avatar
$500... thats way too expensive... i cant exactly say what i paid as i can get it direct, but it should around $150...
Turbo Barra ED 4L
Old 31-05-2007, 09:55 PM   #16
dave.747
dave.747's Avatar
Ive had 2 cat back 3 inch exhausts "custom" made for $450 and $550. One with 1 muffler and res and 1 with 1 muffler only.
edit: I had a 3rd one done for $850 I think incl cat, muffler and resonator.
Ive had too many turbo E series :(
Old 01-06-2007, 03:37 PM   #17
MotherNatureVer2
I have the 3" Redback system on the Sprint ........ I didnt pay anywhere near that amount for it fitted so I think you will be right as far as price goes
MotherNatureVer2 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2007, 08:25 PM   #18
EF_Frmnt
EF_Frmnt's Avatar
rollins old exhaust is now on my car, 3inch is a bit loud cruisin but makes some sweet noise at 6,000rpm only reason i needed 3 inch was for the turbo, so when my new 3in' hi flo cat and all the turbo **** goes on it will be worth a bit of noise.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
