Old 03-06-2007, 11:46 AM   #1
marcy
EB XR8
Question louder
hi guys
I've got a EB XR8 with a 3" exhaust with a turbo lukey muffler but i want it louder. what do you recommend, 2.5 " etc.
marcy is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 11:53 AM   #2
webby_191189
low wagooon
A dual 3 inch system with a straight through muffler each side and dump it at the diff. Or you may be able to run dual 2.5 inch all the way to the back of the car if you want to keep the exhaust in the factory spot
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:15 PM   #3
Mickus
Mickus's Avatar
disconnect the exhaust from the cat :P
Mickus is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:42 PM   #4
frd_crzer
:D:D
frd_crzer's Avatar
run no mufflers at all then it will be loud.
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:42 PM   #5
JUZXR8
Hmmmmm
JUZXR8's Avatar
you would lose waaaaaaaaaaayyyyyyyyyy too much down low power with twin 3inch exhausts....get a good set of extractors and go for a twin 2.5inch system!
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 12:50 PM   #6
marcy
EB XR8
Red face
anyone got pics and also know pricing
Old 03-06-2007, 01:31 PM   #7
mcflux
mcflux's Avatar
Have a chat with MADNC_8 ;) His exhaust is the duck's nuts
Old 03-06-2007, 03:00 PM   #8
~EFhastE3~
~EFhastE3~'s Avatar
get yourself 2.5" full zorst with preferable pacie headers.. then if you still want it louder try and bore your cat.. (not by watching Law & Order).. it certainly has made it louder on my car..
Ben
~EFhastE3~ is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 05:06 PM   #9
castek
but running a gutted cat is illegal.
twin 2.5" would be pretty ideal. most people i know are running em. about $600 from a shop not far from me. but dont know anyone in your area
castek is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 05:18 PM   #10
marcy
EB XR8
I go to Carline mufflers ill get a price from them but everything is usually more expensive up here. I think ill go for the twin 2.5" setup what muffler should I put on , I was thinking a hotdog ?
Old 03-06-2007, 05:20 PM   #11
SVT8
SVT8's Avatar
Highflow cats and a set of extractors will do. You will be suprised how much the stock cats restrict the exhaust once extractors and a cat back exhuast is fitted. I myself have looked into twin 2.5inch systems, but apparently its pretty hard to do as its a tight fit.
I would stick with your 3inch, fit either pacemeaker, el gt (el xr8), or a set of genie extractors. Pacemakers would be the way to go, it will give you a crisp tough roar while your highflow cats should finish off. I think it would be a little bit to loud with a 3inch system on though, so it might be best to look into a rear resonater. Dont buy things for the sake of it, if your going to replace your exhaust do the extractors first, then exhaust. Because you may find that with the extractors on the 3inch exhaust, may be what you are after. If not, then start experimenting with mufflers and straight through pipes on your system.
SVT8
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 05:38 PM   #12
marcy
EB XR8
Thanks SVT8 that sounds like the best thing i should do. ill get the extractors first which i do want anyway. does anyone know of anyone who is getting rid of pacemakers and that would send them up to me .
thanks
