Old 10-06-2007, 01:10 AM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Heat shield on Pacemaker 4499's
Hi All,
Just wondering if anyone has managed to get their standard heat shield back on after installing Pacemaker 4499's.
If the heat shield doesn't fit, are there any other options?
Thanks,
Justin.
Old 10-06-2007, 02:00 AM   #2
RspecAU
BA GT-P Owner
RspecAU's Avatar
Originally Posted by private9
Hi All,
Thanks,
Justin.
What engine do you have? I6 or V8?
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 10-06-2007, 08:50 AM   #3
au2sw
Blown 5L coming
au2sw's Avatar
when we convert a falcon with extractors (I6) we either place a heat shield around the LPG converter, or a sheet of metal spaced off the extractors by a nut welded onto them. ie: weld a nut on every second pipe, then weld or bolt a sheet of thin steel to them. making sure to bend the steel into shape around the bend.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2007, 10:09 AM   #4
Casper
Contributing Member
Casper's Avatar
I have a heat shield on my 4480's. Was just a matter of adjusting its shape to fit.
Older, wiser, poorer.
Old 10-06-2007, 10:10 AM   #5
private9
private9's Avatar
I6.
Casper, when you say adjust the shape, was it just a matter of bending it by hand while fitting?
Old 10-06-2007, 10:17 AM   #6
Casper
Contributing Member
Casper's Avatar
I6.
By hand, by foot.. it needed a lot of "adjusting". I give G&D credit.. they managed to get it on there and make it look kinda stock.
Old 10-06-2007, 12:19 PM   #7
eXi7w0unD
eXi7w0unD's Avatar
i got my 4480's showing is that bad? and 1 bolt is missing is that also bad?
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2007, 12:22 PM   #8
kenz
BOSS Pilot
kenz's Avatar
I have 4499s on my i6 and just told the exhaust guys to reshape the heat shield so it fits back on around the new extractors and thats what they did. Im assuming by hand as they arnt that hard to shape
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2007, 10:16 PM   #9
private9
private9's Avatar
Thanks for all the info guys!
Kenz, that's exactly what I wanted to see. I'll probably bolt the extractors on myself and have a go at getting the heat shield on, and then I'll have a nice quiet drive to the exhaust shop to get the cat modified and matched up the extractors!
Old 10-06-2007, 10:17 PM   #10
private9
private9's Avatar
Sounds like I'm gonna have some fun then! 4480's hang out a fair bit more than 4499's though, so maybe I might have an easier time!
Old 10-06-2007, 10:19 PM   #11
private9
private9's Avatar
Probably not good, but oh well! Just chuck a bolt on that's pretty easy - worst you might be getting is a bit of an exhaust leak.
As for the heat shield missing, plenty do it, but in my experience with a few different cars, is that you end up with a fair bit more radiated heat in the cabin through the firewall, and you tend to melt engine bay parts such as brake booster, wiring, alarm sirens etc over time, this is why I want a heat shield back on.
Old 11-06-2007, 09:42 AM   #12
Mechan1k
Mechan1k's Avatar
Mine is the same as this.
