Hay hay!
Recently I've had problems with my stock sound system, but things are all sorted out now and everything is working fine because of the help of a few very nice and helpful people here who where willing to help me out! Well, now I have another problem. As I was driving down a road in wet conditions (my rear tyre tread was low on both wheels) I came up to a roundabout with a very sharp curve through the whole turn if you wanted to go straight (which I did), as soon as I was half way through the roundabout there was a P plater in a VN drifting around the turn coming up behind me from the right. He lost control and started to slide right towards me uncontrollably and pretty fast, so the only thing I could do to avoid any accident was to speed up. I did speed up and in the end I did avoid him crashing into me, but as I sped up, my tyres lost traction after about 5 meters of driving and the back of my car slid out to the left onto the dirt that was right next to the road. There was a gutter and my BACK LEFT TYRE hit that and bounced up onto the side of the road... So thats ok, nobody is hurt and the guy in the VN was pretty damn apologetic, he also went off the road and bounced over the small gutter onto the side of the road. Blah blah, cut to what my problem is... Now as I drive, when I'm going above about 30km/h I hear a squeak on the back left side of my car, and as I speed up and travel at higher speeds, the squeak speeds up like "squeak.squeak.squeak.squeak" from "squeak...........squeak.............squeak". My original thought was that there must be something wrong with the suspensions or shocks because if I applied the brakes and the weight of momentum was transfered to the front of the car (back of car rising slightly), the squeaking would stop, and as soon as I let go of the breaks, the squeak would come back!. I took the left rear wheel off to inspect everything, but nothing seems out of place. As i'm not very good with identifying things that a wrong because I am inexperienced I was hoping for some advice to what to look for? If you like, I can take photos with the tyre off or on just to maybe help? Thank you! |
#2 | |||
Blown 5L coming
possible that the force of the collision has damaged the wheel bearing is my first guess. im guessing that the handeling hasnt changed as you didnt mention anything other then the squeak, so im going to assume that the rim hasnt buckeled at all. you would feel shuddering as if your tyres needed to be balanced. so i would get the wheel bearings checked first.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
that squeaking could also be the handbrake, the knock may have dislodged the brake shoes enough to make them rub on the disc...the other thing i can think of is it may have warped the disc itself, ie when you brake the pads touch the disc and don't squeak, when they are off it rubs on the pads unevenly....just a thought
MMM, I'm thinking it is the hub cap (you have a forte right?) If you have, leave it off and go for a drive. I had this issue with a Mazda years ago. Obviously if you have mags I'm way off the mark!
hehe ddarby, I don't wear hubcaps on my car at all!
I will check the wheel bearings like as2sw said, and try get it fixed. And yes, the handling has not been changed what so ever. I dont feel the slightest difference in Handling or Breaking, its just a squeak squeak... Im going to check everything again now that I have something to look for! Thank you so much guys! I'll keep you posted. If there are any other people who might have a clue to what it may be, it would be still of great help! |
Sorry, I forgot to mention, if it does have something to do with the wheel bearings, is it going to be dangerous to drive? Also how much fixing would there be required lol!
Peace |
Karasu
No a damaged wheel bearing won't be dangerous to drive, worst case senario the bearing siezes and you either break an axle or you just don't go anywhere... wheel bearings don't usually squeak in my experiance, more often you'll get a dull rythmic rumbling noise. also normal braking shouldn't really impact on the noise (not on disk brake cars anyway, drums are a different story) I'd suspect that your hanbrake is the likely culprit, try driving normally and while the squeaking is happening hold in the handbrake button and gently lift the handle and see if it stops as the shoes center in the drum, if it stops then the hanbrake is the first place to start looking
Walking with God
My bet would be the handbrake as well. Darn annoying they are!
Try looking at these, they may be of assistance to you. Rear Rotor and Pads Change http://www.fordforums.com.au/showpos...5&postcount=54 Filing the handbrake shoes http://www.fordforums.com.au/showpos...2&postcount=68 All the best with it. GK
#9 | |||
![]() good luck |
#10 | |||
Karasu
#11 | |||
#12 | ||
Hey I've got some more news.. Now when I'm braking, I can feel shudders in the foot pedal, and my car doesn't slow down smoothly, instead it slows down like its shuddering.
The best way I can explain it is that it slows then shudder, slows more then shudder, slows more then shudder.... hehe sorry thats the best I can do. Do you guys think its got something to do with the actual brake on my left rear wheel? If so, how much would a replacement cost, or instead, I would just love to upgrade all my brakes at the same time if I have to get them fixed or changed. Oh, and I checked axle thoroughly and its not bent anywhere... Is there anything else I should check or get replaced? At the moment, I really think the problem is lying in the whole brake system, and the wheel, not too sure what its actually called, but the wheel that the pads slow down when braking. Any more help would be greatly appreciated! Thanks! |
the shudder confirms a warped disk
