Old 17-06-2007, 04:42 PM   #1
Falcon Oath!!
Thumbs up What's the safest rim width?
G'day
i.m thinking about getting rid of my 15" mags,and upgrading to 17
" . Kwik question, Whats the safest width or tyre sizes you can use before the tyres rub against the front guards?
oh yeah,the car is a 1995 Gli falcon,standard height.
Falcon Oath!! is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 05:12 PM   #2
bentles
bentles's Avatar
could fit 18s in there even if its alot lower than stock, however they are more expensive outright and to maintain. also on crappy roads id stick to 17's.
if the roads you use are usually good and the car isnt on the grass go for some 18s
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 05:22 PM   #3
Conrad
whats the safest rear width?
Conrad is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 05:29 PM   #4
bentles
bentles's Avatar
oh width how silly of me, lol!
el gt's came out with 8" wide afaik, and they protrude form the guards on regular eseries so 7" would be about max for front, and up to around 8.5" at the back but the wider you go the more you will aquaplane dont forget, so it depends where you live also, as in how wet is it most of the year
i could be wrong here, ive got 7" front and rear and they suit the front fine, but up the back they look a bit too far into the guards, but much more and it wouldnt fit too well either.
Old 17-06-2007, 06:09 PM   #5
Allen
You win again, gravity!!!
Allen's Avatar
EB and EL GT's had 8.5" wide rims, but they had the flared bodykits as well...
8" wide all round is generally accepted to be the norm for aftermarket wheels.
235 width tyres on the front should be fine for clearence on a lowered car, and the rear could take 265's or more easily...
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 06:28 PM   #6
NZ
NZ's Avatar
I've had 255's on elgt rims (genuine) on the front of an eb before, but on an ef/el scrubbing the front guards will be a big issue
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 17-06-2007, 07:10 PM   #7
Falcon Oath!!
Thanks 4 all your inputs on this thread.
I just thought i'd ask here before blowing all my cash on some nice mags,and then only to realise that i can't turn a corner , or do a u-turn without shredding or damaging something !!!!
I've also heard that some 5 stud pattern Toyota , Camry and maybe WRX mags are the same as the Falcon stud pattern. Does anyone know if theres any truth in the rumour?,or are currently riding on other brands?
Old 17-06-2007, 07:26 PM   #8
Conrad
So the rears can have 8inch with 255 tyres on an EF?
Old 17-06-2007, 10:52 PM   #9
MADED-6
MADED.6
MADED-6's Avatar
ive got 19's on hub adapters now and on tight corners if u hit a big bump the fronts scrub the tyres are 245's.
and my car is pretty low but not massive low.
i was going to go lower with some shortened shocks but dont think i will now.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 10:56 PM   #10
LUXO_8
windsor user
same stud patern, different offset,
you'll need to run adapters to fit them
Old 18-06-2007, 12:22 PM   #11
metalhead_mike
i reckn chuck a set of 19's on it and slam it on its guts u cant go wrong with 19's. :
metalhead_mike is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 12:34 PM   #12
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
ive got 18X8 all round with 245 all around also. my car is lowered and i have had no problems with rubbing. check build thread for pics
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 07:38 PM   #13
frd_crzer
:D:D
frd_crzer's Avatar
get 18 with 245 8'' wide on the front and 255 10'' on the rear and that will be safe and not illegal
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 08:01 PM   #14
Allen
Allen's Avatar
10" on the rear and not illegal?? I think not...
That is a track increase far greater than that allowed without an engineers certificate.
Plus I think there is also another rule, where the widths of the front and rear wheels cannot vary too much from each other... I can't remember what the actual percentage is though. (This is more for pro street cars, with tubs at the back and front runners at the pointy end... But the rule still exists)
Not to mention it will cause the car to have heavy traits of understeer in hard cornering... Well, more than a usual e-series anyway... :P
Old 18-06-2007, 09:10 PM   #15
mcflux
mcflux's Avatar
I've got 16x9" rims all round, 225s on the front, 245s on the rear. The 245s coupled with 9" rims are skinnier than 225s with a 7" wide 15" rim due to zero sidewall bulge.
I'm currently waiting to hear back from a MT supplier about 295s but they're taking their sweet time with their reply!
Old 18-06-2007, 09:49 PM   #16
Falcon Oath!!
I've got my eyes on some 17"mags (apparently meant for ef-el falcon),that have Falken tyres on them. 255/50/r17.
The rears will fit ok,but tried out the front today and it wouldn't fit properly as the tyre touches the wishbone cos of the 50 height.
They are a great looking set,but to get em on the front, i'm thinking about getting the studs taken out of the rotors (i have a slotted set in box to be put on),and longer ones fitted so it could handle a spacer of about 25mm (?),then that should get the tyre away from the wishbone and hopefully i can still do full turns without anything rubbing.
Am i on the right track,or am i up the proverbial creek???
Old 18-06-2007, 10:42 PM   #17
NudgE^SIKBRO
Never late with a V8
NudgE^SIKBRO's Avatar
I have an EB with Genuine ELGT's on it, its lowered on superlows and the tyres are 235/40 or some crap... they scrub on the guards entering driveways etc
My Rides
(Daily)2004 Explorer V8 Limited
(Work) 2014 Kenworth K200 Aerodyne
(Classic) 1969 Mini K, 1340, twin SU's
The beginning is near!!!
Body by Ford. Soul by NudgE
NudgE^SIKBRO is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 11:21 PM   #18
Conrad
Ok, can we ignore what eachother has.
Whats the widest, legal set of rims and tyres for the rear?
Whats a good set of front rims and tyres to suit the rears?
Old 18-06-2007, 11:26 PM   #19
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
Ok Boss :
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 11:37 PM   #20
Conrad
Wanting to buy a set of rims asap sorry if i was rude.
Love 4 all
Old 19-06-2007, 10:32 AM   #21
mcflux
mcflux's Avatar
Conrad, widest LEGAL rim width is 1" wider than factory, and largest LEGAL rim diameter is 2" larger than factory. If your EF came out with 15x7s, you can go as large as 17x8. Same goes with the factory tyre size. If you had 205s, you can't go past 225s (legalls), as 235s would leave a footprint a tad over an inch wider than 205s.
The legalaties are crap though, just run the risk & get whatever *you* like. I did As long as you know the risks (potential defect, potential void of insurance) and you're happy with the consequences, go for it.
Old 19-06-2007, 11:12 AM   #22
Plunkett
never enough power
Is the 1" wider and 2" larger Diameter rule the same for the front of the car? does IRS change anything?
EA Fairmont Ghia sleep:
EA bottom end, AU tickford XR6 head JMM DEV 5, Race series headers, 5-speed manual, 3.7 LSD diff, sports suspension, sports brakes, all rapped up in a 89 champaign coloured falcon gl shell.
Plunkett is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 11:27 AM   #23
blur1
el wagon
the LAW is the same and irs doesn't change that.
blur1 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 12:38 PM   #24
mcflux
mcflux's Avatar
^^ as he said.
1" wider (or narrower) from factory MAX
2" larger (or smaller) from factory MAX
Rolling diameter as well can't change by more than 1"
Old 19-06-2007, 06:24 PM   #25
Conrad
Cheers big ears'!
