Live in canberra, travel to work everyday in slight stop start traffic, dont give it to her that often what fuel consumption should i be running at?
EL Fairmont. |
EBII XR6
Judging from my trip computer I'd say around 12 or 13L/100km.
Which isn't too bad, BA's are about 10L/100km.
DEVLXR
yeah thought so, apparently ive got something wrong with my manifold housing, my mechanic poured water over it and the whole car starting mis-firing, he quoted me 300 to get it fixed, he reckons its 3 hours labour for a fairly cheap part.
he said something about my computer will be suckin a bit of air so i may use a bit more petrol until its fixed. at the moment im at 13.8L/100km |
he said the manifold houseing will be suckin in some air so the computer will be wanting to use more petrol...
haha that sounds a bit better. |
Yeah i guess anywhere between 11.5-14 would be about right.....
Consider changing your o2 sensor as well, i did this and got a huge improvement ![]() |
#6 | |||
The 'Stihl' Man
![]() Join Date: Jan 2005
I haven't looked to my average around town, on the highway it sits on 7.
ORSM FORD CRUSIERS
oh I wish mine was like that! 7ltrs per 100km.... im getting 18ltrs per 100km,
it will just be a manifold leak nothing major, go over all the bolts make sure they are tight and make sure the hoses etc are all done up tight and are on correctly, will save you 300 bucks and you learn a lot along the way!
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#8 | |||
EBII XR6
DEVLXR
#9 | |||
ORSM FORD CRUSIERS
you can run a diagnostics test as shown in on of those gregorys manuals, or you should be able to tell as it will be running rich and using more fuel than it should, they are avalible from autobran and they are not cheap!!!! and don't get dodgy brand one, get BOSCH one rounghy $170???
#10 | |||
The 'Stihl' Man
#11 | |||
ORSM FORD CRUSIERS
#12 | ||
yeah my old man and i are looking over it this weekend.
about to put Sports exhaust and extractors on it in a few weeks, so want everything to be running smoothly for that little installment. |
your all doing better than me, my nl fairlane has been sitting on 14.7l per 100km for the last 2 weeks and barely moves even when im on the highway doing 100k's in no traffic and its a 6 cylinder!!! and i havnt even been lead footing it in fact ive been taking it really easy.
#14 | ||
The 'Stihl' Man
Mind you this is off the trip computer, it could be lying to me, but I doubt it.
Mike, your issue is with the old equation F=M*A
#15 | |||
#16 | ||
The 'Stihl' Man
Force = Mass x Acceleration. Which means barge ar$e = fuel consumption
All large Fords deal with it, just Fairlanes are slightly worse. You can have the most efficient engine you like, its still got to lug alot of weight around.
#17 | ||
but im only 78kg's and ive been the only 1 in the car the whole time
#18 | ||
Ute Forum Moderator
![]() Join Date: Dec 2004
I'm tipping the car weighs a bit more than 78kg!
Re the intake leak, you may need to replace the gasket, mine cracked and a small piece came loose on #6 cylinder |
#19 | ||
trying to get a leg over
I can get my EL ghia down to about 9 litres per 100 on the highway, but around town stop start heavy traffic it gets around 14.8-15.5 litres per 100.
replaced 02 sensor and it didnt seem to do much, might look at replacing injectors next
Cameron ------------------------------------------------------ |
#20 | ||
What's green is gold
My EL ghia 6 is about 11.8 which is a fair mixture of driving in town, and country roads/highway
The XD, well, about 18L/100k's...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#21 | |||
from what the mech was saying it sounded like he had to pull off a fair few of the bigger parts.. it runs okay, its not missing anymore, its just a bit slow and sometimes sluggish. cant wait to fix it and have a smooth ride again. its been like this for a few weeks now.. |
#22 | |||
FG G6ET
