Old 19-06-2007, 11:54 AM   #1
Brewtal ED
Brewtal ED's Avatar
Default Next step for the ED
Hows it goin,
Ive come to the crossroads with my car. Its a manual I6 ED, with full Genie 2.5" exhaust system. Now originally, i wanted to turbo the car, but with saving for a house looming over my head, that looks very slim, so im thinking of squeezing as much as i can out of the motor i got. i have a little over 3 grand to spend, so i was thinking, should i jsut go for a wade/crow cam (preferablly crow as i can get them easlier) and stay with my exhaust system, or should i go and get a DEV3 kit and install that? or drop a v8 in (id prefer to stay manual)? or any other ideas?
Any input would be great
Trav
1993 ED Falcon
2.5" Full Exhaust System
Lovells Low Springs all round
2002 AU XR6
Manual, current project
2004 BF Fairmont
Stock - family car
Brewtal ED is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 12:03 PM   #2
[Tonko]
What's green is gold
[Tonko]'s Avatar
You cant dose in a house. Go for the turbo!
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 12:27 PM   #3
mcflux
mcflux's Avatar
Stick with a six. For a $3k budget, stick with an atmo six. Have a gander in the e-series tech section of the Ford Sixes section for atmo setups ;)
Old 19-06-2007, 12:28 PM   #4
mcflux
mcflux's Avatar
What if he has a long driveway? :P
Old 19-06-2007, 12:29 PM   #5
OED666
OED666's Avatar
au motor, cam, tune... maybe pacemaker headers, shorter diff gears.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 12:42 PM   #6
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
and bob's your uncle!! :
It will be ready to do the hokey pokey ======
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 01:23 PM   #7
Brewtal ED
Brewtal ED's Avatar
Will the AU motor bolt up to my EDs manual gearbox? I want to stay manual, and dont want to have to buy another gearbox?
1993 ED Falcon
2002 AU XR6
2004 BF Fairmont
Stock - family car
Old 19-06-2007, 01:27 PM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
YEP!! i had an au engine in my EB with the manual trans. the two bottom bolts don't line up but don't worry about them they are not nessasary, I had a turbo on the Au engine and if it were going to run in to any trouble missing two bolts i would have found out. they only stablizer bolts.
Old 19-06-2007, 01:42 PM   #9
Brewtal ED
Brewtal ED's Avatar
how come they dont line up? EL engine lines up i think? why wouldnt the AU? or is there a difference between ED - EF/EL/AU?
1993 ED Falcon
2002 AU XR6
2004 BF Fairmont
Stock - family car
Old 19-06-2007, 01:44 PM   #10
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
the sump is different on the au's they are a cast sump. no biggie also to fit it in you need to get a angle grinder and grind off he casting ribs on the front of the sump to fit it in 5 min work!
Old 19-06-2007, 02:13 PM   #11
Brewtal ED
Brewtal ED's Avatar
would it be easier to grab an AU engine and put an EL sump on? or just easier to angle grind and not bolt up the bottom 2 bolts?
1993 ED Falcon
2002 AU XR6
2004 BF Fairmont
Stock - family car
Old 19-06-2007, 02:16 PM   #12
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
the el sum doesn't fit on the AU engine, it has to have the Au on it. it is really easy to fit it all in, and grind that stuff off and the problem bottom 2 bolts can be fixed by using a au bell housing from an manual au as it will bolt up to the t5 you have allready.
Old 19-06-2007, 02:34 PM   #13
Brewtal ED
Brewtal ED's Avatar
ah ok, changing the subject just a little bit, how come my current box wont bolt up to ?v8 even if i did get hold of a manual v8 bellhousing?
1993 ED Falcon
2002 AU XR6
2004 BF Fairmont
Stock - family car
Old 19-06-2007, 02:53 PM   #14
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
if you did put a v8 in i think the gains you would get is so minimal verses the cost of getting it done, as you will need to get an engineers report, change the loom, new ecu, lots of stuff needs to be done as you say you haven't got much $$ saty with the I6
Old 19-06-2007, 03:06 PM   #15
Polyal
The 'Stihl' Man
Polyal's Avatar
How about selling it and getting a XR8? Much easier, just get a nice clean EB SXR8. I see no point in getting en ED unless you really like the lights, just dont prang the front.
  • 1973 ZF Ford Fairlane
Old 19-06-2007, 07:02 PM   #16
MADED-6
MADED.6
MADED-6's Avatar
man keep the i6 theyre better anyway/easier to get power out of.
just put in a low k au motor and get a dev5 or a big crow cam and a chip and ull have probly 160-170rwkw.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
