Old 20-06-2007, 03:38 PM   #1
The Monty
Just slidin'
The Monty's Avatar
Default CAPA flash tuner on AU turbo
Just a quick qeustion, not sure if anyone will know an answer.
Is the CAPA flash tuner (AU, BA, BF, Territoty) able to tune turbo Au's?
I know it can do AU's but do Au turbos fall under the same category?
Thanks guys.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 20-06-2007, 03:52 PM   #2
RG
Back to Le Frenchy
RG's Avatar
I can't see why it wouldn't, if it can tune XR6T's to some of the power figures they put out it should be able to tune the AU similarly.
Old 20-06-2007, 04:51 PM   #3
b2tf
not here much anymore
b2tf's Avatar
yes it can.
2024 F150 XLT
Old 20-06-2007, 04:57 PM   #4
RG
Back to Le Frenchy
RG's Avatar
^^^^^abbreviated version.
Old 21-06-2007, 04:08 AM   #5
The Monty
Just slidin'
The Monty's Avatar
Cool, thanks guys.
Old 21-06-2007, 05:06 PM   #6
TCK-098
TCK-098's Avatar
You still thinking about fitting the turbo kit to the mont are you josh.
It would make a great sleeper though...... :evil3:
Pete
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 06:04 PM   #7
The Monty
Just slidin'
The Monty's Avatar
I know.
Its just I have most of the parts here. I just need something to run it (CAPA flash), injectors (24lb+) and some piping and then install and tune it. But then theres other extras like an LSD, and a shift kit and tranny cooler. A gearbox rebuild if it blows, and a new engine if it dies. But all that still works out cheaper than buying that GTR, lol.
Old 21-06-2007, 06:15 PM   #8
Mechan1k
Mechan1k's Avatar
I found out yesterday Magna 2.6L injectors are the same as the Ford Motorsport 24lb injectors (and I think a hell of a lot cheaper as well).
Old 21-06-2007, 06:20 PM   #9
The Monty
Just slidin'
The Monty's Avatar
Cheers mechanik, that helps a massive amount
Old 21-06-2007, 06:25 PM   #10
Mechan1k
Mechan1k's Avatar
Check it out ... I'll confirm though first ... then get you firm details.
Old 21-06-2007, 06:33 PM   #11
The Monty
Just slidin'
The Monty's Avatar
Does anyone know if the beige tops (706) fit in the au? Or does anyone know what colour injector is what, like the blacks are____lb the blues are ____lb, the etc etc..
Old 21-06-2007, 07:26 PM   #12
bomber
bomber's Avatar
The Flash Tuner will be able to work and a forced setup how ever you will be paying a fairbit more for dyno tuning to get the same result as you would say a wolf v500 or other After market ecu you will end up paying about the same for tuning alone as what an aftermarket ecu installed and tuned will set you back as tuning a flash tune is not on the fly.
bomber is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:17 PM   #13
b2tf
b2tf's Avatar
orange ones are used in eseries V8's, from memory they are somewhere round 18lb but not 100% on that.
Blue tops are standard fitment on all AU V8's and are 24lb.
2024 F150 XLT
Old 22-06-2007, 02:19 AM   #14
The Monty
Just slidin'
The Monty's Avatar
Why I was thinking of the Edit instead of the other types, is that the Edit is regularly going for under 600, and the other types go for up to 1500. That leaves me with 900 in tuning, before it even comes to the purchase , let alone tuning, price of the other types.
Old 22-06-2007, 01:34 PM   #15
bomber
bomber's Avatar
Yeah i was going to go down the same route and investigated this. You will most likely pay more than an aftetermarket unit is worth in just tuning on an flash tuner and once you make more modifications you have to do it all over again. It would be a nice cheap option but it is not the case.
Old 22-06-2007, 05:13 PM   #16
xr8ute
Back on the road
xr8ute's Avatar
You want to be careful with Bosch injectors, colours, and flow ratings......its not as straight forward as it used to be.
I've got two sets of identical looking blue Bosch injectors. One set flows 39lb/hr, and the other set flows 24lbs/hr.
Also...not all flow ratings are at the same fuel pressure (i.e. XR6/XR6T/F6/"Magna" injectors).
Safest bet is to cross-reference the part number.
Old 22-06-2007, 05:42 PM   #17
sly
Sly like a G6
sly's Avatar
Edit v's aftermarket really comes down to personal choice. My local flash tune shop reckons that when I put a blower on my AU, they can wire in a MAP sensor that measures boost as well as vacuum then edit the ECU to respond to boost (rather than just editing the existing advance/RPM/load map). This should give protection from pinging on overboost, probably more important for a turbo setup than my planned CAPA kit.
Sleeper, anyone?
Old 25-06-2007, 06:54 AM   #18
Mechan1k
Mechan1k's Avatar
That's what I was told ... don't just go off the colour .... make sure first that the part numbers and flow-rate and pressures are identical.
Old 25-06-2007, 08:14 AM   #19
Stav
Smile
Stav's Avatar
Look up powerflow injection on the net.Then call them for advice. They know their stuff. They sell pumps injectors and alot of associated equipment.
Old 25-06-2007, 05:32 PM   #20
stiddy
stiddy's Avatar
Or just buy some Green tip 42lb ford motorsport injectors for $390.
Old 25-06-2007, 05:58 PM   #21
The Monty
Just slidin'
The Monty's Avatar
390 each???? If thats an each price, there is no way in hell I would pay that.
Old 25-06-2007, 06:29 PM   #22
stiddy
stiddy's Avatar
All up.. Cresent motorsports sells them at that price.
Old 25-06-2007, 06:40 PM   #23
The Monty
Just slidin'
The Monty's Avatar
Ohh!!. I was going to say, I picked up a set of F6 injectors, 32lb, for a fairbit less than that. Then found out they dont fit....
Old 25-06-2007, 07:05 PM   #24
stiddy
stiddy's Avatar
sell them, and go for the ones I mentioned.. you cant go wrong.
