Old 20-06-2007, 06:02 PM   #1
Falcon924
Default EF power steering fluid
Hi, I'm about to replace the steering pump on my 96 EF II Gli 4.0, and was wondering what fluid to use. The manual I have says Mobile 424 but I couldn't find it. At Supercheap they had Valvoline Type F which was recommended for EL's and AU's is that stuff OK for the EF, I thought the EF was the same setup as the EL & AU. The Valvoline book said to use Type D 225 i think but all they had was Type D is that the same? It's a transmission fluid but I remember my EA used dextron III for the steering and transmission. And so Could someone just let me know what the best fluid to use is, I'd imagine most of these would work OK being hydraulic fluids but I'd just like to be sure.
Falcon924 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 07:20 PM   #2
lorne
Ford i6
dextron 3 will do
lorne is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 09:27 PM   #3
MrFlibbles
ill have a beer milkshake
MrFlibbles's Avatar
dexron 3 will do it but i use the later el/au fluid
current cars:
2001 AU SII XR6 manual
2001 Nissan Patrol
1969 Isuzu Florian
1976 Chev luv (really its just a rebadged Isuzu!)
1980 Isuzu KB 4x4
MrFlibbles is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 09:29 PM   #4
atec77
same fluid as the auto
Old 21-06-2007, 12:07 PM   #5
SrsIIE8
Blue blooded rev head
SrsIIE8's Avatar
They recommend Mobil 424 because it minimises squealing. Just find a local garage that sells Mobil products and they will be able to buy some in with a stock order if they dont carry it. Type D wont be the same as Type D 225 but the difference most likly wont be noticible except for maby when the fluid gets hot it might get noisey or shudder slightly but i doubt it. at the end of the day anythings better then nothing.
My prized possesions
Dynamic White EL Srs2 XR8 5spd, factory sunroof, 2 1/2 cat back, lightened race ready flywheel
3 x Mk2 Cortina's, One with K-Mac fully adjustable's, Nolathane bushes, Celica 5spd, Bored and polished to about 1900, Twin 45mm side drapht webber's, Custom woodgrain dash, + a few more goodies
SrsIIE8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 03:30 PM   #6
niko
likes falcon's
niko's Avatar
put in the brown stuff...copes better with heat
you should really have it in your ef....
www.carhubsales.com.au
Old 21-06-2007, 03:45 PM   #7
Falcon924
Thanks guys. which one is 'the brown stuff'?
Old 21-06-2007, 03:48 PM   #8
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
95le..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 04:12 PM   #9
niko
likes falcon's
niko's Avatar
walk into any ford and just ask for BA power steering fluid recommended for ef to current
