Old 23-06-2007, 05:54 PM   #1
Dave XR6
Unleash The Fury(s)
Dave XR6's Avatar
Default Aftermarket sub woofers
I'm wandering if its possible, having premium sound fitted in my XR, can you put and run an aftermarket sub off the factory amp? People say you can but i don't know for sure. It may be a stupid question but i have the equipent but unsure.
Modded Black AU II XR6
Super Low King Springs
2.5'' Mandrel Bent Sports Exhaust
19'' ROH Fury's
De-badged thanks to a couple of 15 yr olds
Dave XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 06:12 PM   #2
The Monty
Just slidin'
The Monty's Avatar
I dont see why nt, its just that the amp is most likely not very powerfull, and the result may not have the desired effect.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 23-06-2007, 06:21 PM   #3
Big Mike
Acid Rush XB Coupe
Big Mike's Avatar
Plug it in and try it!
Are you basically upgrading the crappy one in the parcel shelf?
In which case yes of course it will work! **BUT** Make sure the impedance (ohms) and power is compatible with the amp output. You CAN buy a better unit than the factory one, and still be compatible.
However, the easiest way to do it is to fit a new AMP as well as SUB, patching in to the sub output (the feed IN to the factory amp) and use that as input to your new amp.
Modern GT flavour, XB Hardtop, modern 7.5L, F3TE-spec EFI 460 BigBlock 5spd Tremec manual!
Big Mike is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 07:03 PM   #4
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
THEN you'll want to upgrade the speakers coz they cant keep up with the sub..then you gotta upgrade the head unit to run the flash new speakers..its a nasty cycle...ive been sucked into it...and love it
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 10:54 PM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
you can buy good Amps for less than $300 , or get a Big Mumma Class D response Amp from JayCar , the Ducks Nuts !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 09:48 AM   #6
JoesAu
JoesAu's Avatar
i did it for a while, i ran a 10 inch subby in a box off the factory amp sounded better than the 8 inch one thats for sure, then i just went out and bought a whole system
JoesAu is offline   Reply With Quote Multi-Quote with this Post
