Old 27-06-2007, 02:44 PM   #1
Hunter
Ex EL Falcon
Hunter's Avatar
Default So I went and had some wisdom teeth out...
Well today, I sit here, home from work and sore as buggery contemplating what made me go and get my two left wisdom teeth removed! I mean sure the gum played up occasionally but christ this is painful! Didn't feel much while he was doing and it was fairly straight forward (took less than an hour and didn't need any major cutting/digging, teeth just went straight out) but about an hour after I left the anesthetic wore off and blimey it hurt. I had to drive and see my sister to go and buy the painkillers because I couldn't talk... on the way back I was in severe pain (couldn't take the codeine before leaving cause it makes you sleepy).
For about ten minutes I was in pure hell: I was in blazing agony and literally, no ****, surrounded by Camrys of various models all refusing to speed up and merge. Then came the two diesel shitheaps blowing smoke everywhere and climing a hill at 20 km/h.: :togo:
If there's one time to get a speeding fine, it was yesterday! I can safely say I've seen hell fellas and its not pretty. Try and avoid going there!
Anyone else has their wisdoms out?
Our Lady of Blessed Acceleration, don't fail us now!
Hunter is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 02:54 PM   #2
monkeydog
Shift for brains
I had them all out in one go, but under general (-:
Came home and got back into things, dribbled a bit of blood though.
No pain, only the worry of ripping the stitches out when brushing my teeth.
Soon enough you wont know that you've had them out though.
monkeydog is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 02:55 PM   #3
macman
macman's Avatar
I hope you have a speedy recovery, sounds like a painful ordeal.
I had all four of my wisdom teeth cut out about a year ago and i remember it hurt like hell. I have no idea how you could drive after, they give a hell of a lot of pain killers and numbing injections!!!
Did you get to keep the teeth? I got to keep mine (they're all drilled in and a bit mangled!!!) now got a bag of EIGHT of my adult teeth that i've had removed over the years.
Buy lots of yogo and soup and take it easy! Mmmmm yogo...
macman is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 02:58 PM   #4
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Had all four of mine out last year.
Was eating solids the next day.
Back at work the day after.
Next to no pain.
Carless
Old 27-06-2007, 03:00 PM   #5
mcnamg
mcnamg's Avatar
What does it cost to get wisdom teeth removed?? I have never had any major dental work done but have heard from colleagues that teeth removal costs a fortune
mcnamg is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 03:07 PM   #6
Hunter
Ex EL Falcon
Hunter's Avatar
Cheers fellas,
I'm hoping the bleeding will stop entirely soon - its a very slight seeping at the moment, lots of dribble tho. I had to put a towel on my pillow last night after I work up in a pool of bloody dribble. :
I had mine out under local so I was conscious the whole time - the top one took less than 5 minutes to come out and the bottom took him about 20 minutes to 1/2 hour. The reason I could drive was that I was only given a local and no sedatives or anything like that but driving when you're in severe pain is quite difficult and you tend to have NO patience or tolerance for slow idiots.
Only cost me $330 to have the two out and so far I've spent $30 on Nurofen Plus, antibiotics and some gauze pads. It can cost a lot more depending on how difficult the removal is of said teeth - mine weren't impacted and the only reason I had them out was the lower left kept rubbing/cutting the gum around it and last week it swelled up for the second time (the first time I had problems I had a serious infection in my gum). Basically the bottom left wasn't fully erupted meaning one corner of it wasn't fully out of the gum line. The top one wasn't causing grief but removing just the lower one and keeping the top one can be very painful and make your mouth feel odd. My right teeth, as far as I know, are fine and have fully erupted.
Some people have to have full on surgery to have their wisdoms removed because they need to a) put them under a general and b) cut into their gum and possibly jawbone to extract. Sometimes they even grow sideways. Thankfully mine grew UP else I'd probably be in a lot more pain!
I should've got Nandos on monday night - I really want it right now!
Old 27-06-2007, 03:15 PM   #7
Falcon_Phill
1967 XR Falcon
Falcon_Phill's Avatar
****. I have to get mine out very soon, theyre going to screw up my mouth otherwise. Now im defnatly not looking forward to it.
Coflash.com
Falcon_Phill is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 03:18 PM   #8
FRDGAL
GT-P #0336
FRDGAL's Avatar
I had all mine taken out in one go. I copped an infection though, on the left upper jaw. Got put on anti-biotics. I was given a prescription for Panadeine Forte but they did absolutely nothing to calm the pain. Neurofen was the only thing that worked. I found it to be the best for toothache. After that, all was well. If it wasn't for the infection, I don't think I would have had any dramas at all. I know a few people who have had them all out at once and by the end of the day they were fine.
Anyhoo, I hate dentists with a passion!! Lol I was meant to go yesterday morning but I rang them about ½ an hour before I was meant to go and changed the appt for another one in 3 weeks time. I do this all the time. Once I'm there I'm fine. I can relax and be calm. It all gets done and everybody's happy. My problem is the nerves beforehand and having the courage to actually go.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 03:19 PM   #9
macman
macman's Avatar
Wow, some different experiences from my own there on different levels of severity.
Sounds like yours came out relatively easily and weren't too much of a problem so you're likely to ahve a quicker recovery than i experienced.
My four took over an hour to remove, and i was consious and awake the whole time, lots of pushing, drilling and scraping LOL but most of the pain i experienced was over the next 2 days or so.
In a way, you're lucky as you have one side you can chew on!!
Old 27-06-2007, 03:20 PM   #10
Hunter
Ex EL Falcon
Hunter's Avatar
Oh if you have to get them done you have to get em done. I don't want to scare you or anything but what went on with mine was relatively simple, apparently there are a few other risks but the risk of complication in such a removal is less than 2%.
Did I mention the dentist dropped one of my teeth and it went flying onto the floor
True! I'm going to try and eat scrambled eggs tonight, buying my girl a steak to eat though
FRDGAL_AU6: Sounds like yours were very nasty and I don't blame you for hating the dentist. I'm not a fan of them either, usually I end up in physical or financial pain
Old 27-06-2007, 03:37 PM   #11
Feathers
Lucifer's Angel
Feathers's Avatar
When I was younger and had braces the orthodontist ordered X-rays and said my wisdoms were impacted and all had to come out by the time I was 16.
I never bothered going to a dentist, until last year for a general check up and clean, some 8 years after my braces came off.
The dentist said my wisdoms have corrected themselves and are no longer impacted, so they can stay.
SINISTER BA XR6
Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford...
It's being beaten by a girl driving a Ford
Feathers is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 04:18 PM   #12
SB076
SB076's Avatar
I had 8 teeth taken out once (all my wisdom teeth plus others - was going to have my jaw broken and reset) Getting the teeth taken out wasn't too bad (was knocked out a the time) so came to was driven home and was fine the next day - although I did swallow a bit of blood during the op which was not good as I found out. The jaw op was very painful though - 6 hour op very messy
VIXEN MK II GT 0238
with Sunroof and tinted windows
with out all the go fast bits I actually need :
SB076 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 04:25 PM   #13
BlackLS
:S I'm thinking I may need some out. My bottom left is not completely impacted, been like that for 2 odd years, every now and then the gum gets swollen, and sometimes I can taste blood from that area.
Old 27-06-2007, 04:25 PM   #14
XR6Gal
Just Super Happy now :)
XR6Gal's Avatar
I had my 4 wisdom teeth & 2 other teeth removed at the same time a few years ago, I made sure that I was put under for it (I freak out at the dentist at the best of times) but I was off work for a week because of it & got the most awesome bruise that went all over my cheeks, chin and neck.
PhantomBA XR6 (Sold), now a VW owner (don't hold it against me )
& also a CM Valiant Wagon, gotta love the old Val's
see her progress here
NOW SOLD :( but now have a
Honda CBR250 Motorbike
XR6Gal is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 04:39 PM   #15
Tuddy200
Reaching for 200...
Tuddy200's Avatar
Ain't you glad fellow forum members are here to make your experience heart warming?
Tuddy200 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 05:16 PM   #16
Fairlane
V8 Powaah
Fairlane's Avatar
Wisdom teeth is no fun at all.
Now i was crazy stupid or crazy brave depends on your take and got all 4 pulled at once under local only. One of them took 3/4ds of an hour.
Bleed for about a week, couldnt really eat solids and it looked like id been hit in the face with a golf club. No fun at all i didnt mind dentists until then, now i hate them with a vengance.
Some people have a good recovery though and i hope yours goes well.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 05:30 PM   #17
FRDGAL
GT-P #0336
FRDGAL's Avatar
Yes and no. 3 of them weren't really that painful when being removed but 1 was agony. And the infection afterwards didn't help. The infection was where I had the freak wisdom tooth cut out. It had 3½ roots and caused alot of issues when they were trying to take it out. First they broke it trying to remove it then it was just all downhill from there LOL. Neurofen did the job though and it all cleared up but yeah, as if it wasn't bad enough that I went there petrified and then to have to go through that and the 2 weeks of infection. Doesn't help with following visits lol.
Old 27-06-2007, 05:41 PM   #18
JamesR
i had all mine out, one at a time over a few weeks just at the dentist.
i was lucky, the roots were straight, so they came straight out.
not too much pain, bit of a headache, and a day off work after each one.
i got private health insurance before getting it done, just got some medibank extras thing.
i got about half back of what i paid.
so that wasnt too bad.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 05:46 PM   #19
FRDGAL
GT-P #0336
FRDGAL's Avatar
Just curious, with Medibank, how long did you have to wait before you could have the dental work done?
Old 27-06-2007, 06:00 PM   #20
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
An individual tooth, pulled in a dentist's chair, costs about $100 in total. Prob $110 with GST.
But if you have day surgery (i.e. go to hospital, get knocked out for the procedure)... well, let's just say if you dont have private cover then dont even ask the question lol. I suspect aneathetist fees would have three zeros on the end of it alone. Then bed/room, plus $$$ for the operation itself... etc etc.
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 06:28 PM   #21
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I had the top ones out, one at a time a week apart so I could still eat, wasn't too bad. Hunter I have to say I would have been going the painkillers and taxi home!
Old 27-06-2007, 06:29 PM   #22
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
This brings back memories......
Had the 2 left ones out first a few years ago. Came out no worries, got stiched up and drove home after going to the Chemist to get whatever pills were written on the paper. I spoke like I was paraletic so I just pointed to my jaw and showed the lady my 2 teeth in the bag and she knew what I needed without looking at the paper.
After a week the other side had to be removed. Boy... the top one slid out from sheer fear I think, the bottom one needed to be sliced into 4 after almost an hr of tugging and yanking. The roots were hooked at almost a 90 degree angle...
No pain, drove home. Just a sore neck from this dentist trying his best...
Old 27-06-2007, 06:34 PM   #23
MattyJ
Heaps of people i know are getting them taken out lately... I've got mine and they fitted in just perfectly. Once you've got them, and your teeth are all sweet - does that mean i'll have no future problems and need them removed or ?
Old 27-06-2007, 06:56 PM   #24
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
I had top 2 wisdom teeth removed several years ago, was in next to no pain...got it done under local anasthetic. A couple of hours later, I was back to normal...some have it luckier than others I guess!
Old 27-06-2007, 09:33 PM   #25
Hunter
Ex EL Falcon
Hunter's Avatar
Not always - they can cause problems down the track, and the older you get, the worse they become and the harder they are to come out. Apparently your jaw can even shatter if you're say 40+ and other nasty ****. IMO I'd get it checked out, especially if you're in your teens because the longer you leave them, the more 'embedded' and deeply rooted they become.
Geez some people have it lucky, either that or you have very high pain threshold!
Old 27-06-2007, 11:11 PM   #26
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
I remember when I had mine out a few years back, under general anaesthetic. I woke up in a hospital bed with a mouth full of cotton wool and almost hitting panic thinking "what the hell? Have I been in a car accident and smashed my face up??" before I remembered what was going on and why I was in there.
Nurse was kind enough to pump some sort of amazing substance in my body and asked if I was still in pain. The brain clicked that if I said yes, I would get more (even though I wasn't in pain). My god that was wonderful whatever they were putting into me!!!
Then the following week I laid in bed watching movies & sleeping while dosed up on painkillers for no apparent reason.
What a wonderful experience it was Although, having to eat mushy food for the week was the worst part :( The night dad bought home some KFC Potato & Gravy, I was a happy man!
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 11:25 PM   #27
HOON69
HOON69's Avatar
had 3 of mine removed and am desperate to remove the 4th as its been giving me hell for years
i felt more pain removing the 3 then afterwards
only got min pain relief hence why it hurt a tad when removing
your mouth will thank you for removing them trust me on that ;)
HOON69 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2007, 09:18 AM   #28
Eb Barbie
Eb Barbie's Avatar
Eeek! My dentist told me that my wisdom teeth don't look like they will come up, but if they do no way do I want the dentist to touch em now! That sounds like hell! Poor bugger! Hope the pain goes away real soon
Eb Barbie is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 06:24 PM   #29
JamesR
3 months i think?
but i signed under a special promo, so the waiting period was waived.
my photo blog;
Old 29-06-2007, 06:28 PM   #30
TEKILA
formerly AU_bullet
TEKILA's Avatar
well its time for me to have my wisdom tooth out, top right tooth. only the one (lucky) going under general on monday to have him out and having another tooth pulled (bottom front incisor) as i have recently had braces put on which requires it to be pulled. sounds f'd but its for the best.
TEKILA is offline   Reply With Quote Multi-Quote with this Post
