Hi all,
my Ford stacker (AU II Fairmont) red 'load' light wont turn off and the stereo wont turn on. The screen doesn't come on so it doesn't prompt me to enter the pin number. Does anyone know what the heck is going on? Please Help Cheers FORDavid |
The Origional, The Best
sounds like the unit is blown, which is standard for the stock unit. i'd be looking for a new one
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
#3 | |||
Back to Le Frenchy
It's dead. You need a new one.
Behind The Mixing Desk
Yep, had the same problem. Try disconnecting the power overnight and then reconnect it in the morning. This worked for me and for one of the guys in the T-Series Appreciation forums.
"If there was a drug that could make you smarter, but would cost a fortune, could you afford not to buy it?"
#5 | |||
Blown 5L coming
it seems to be a common problem with the factory in-dash stackers. your best off upgrading your system. there are plenty of options for double DIN or single Din out there. if you go with a single DIN option, you will need to consider getting the change pocket from a low series model though to fill the hole under the head unit. of course, if funds are tight (like mine) perhaps as suggested try disconecting power to the unit over night to reset it. you may just have to do that from time to time though. good luck
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
Thanks for all the advice everyone,
as for the suggestion to try disconecting power to the unit over night - how would i go about doing that? Does that mean disconnecting the battery from the car or just the unit itself, because i wouldn't know how to do the unit. Cheers FORDavid |
I had the same issue in my stacker, pulled the fuse and the unit reset itself and happily plays all my favourite tunes. Has performed well for many years since only rejecting a couple of my itunes burned CDs.
cheers Bill.
AUII XR6 VCT ute 20 years and still going strong! |
Monsoon SIII XR8 220
Don't forget you will need the pin to unlock it when you power up again. I had same prob couple of months ago, worked for me but had to go to ford with rego papers to get the pin.
cheers, Simon |
happend my xr6 VCT when it was brand new all the time, just disconnect the battery and it was all good again, for af ew months..
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25. |
Yep, i just disconnected the battery for an hour and all was good
Thanks for the advice everyone |
#11 | |||
Thanks |
#12 | ||||
#13 | |||
Thanks for the explanation though !! |
#14 | ||
Remove the fuse marked Radio 1 and leave the car turned off overnight
Reinstall the fuse in the morning. You will need the security code. |
#15 | ||
Thanks every one for the advice, I looked up the fuse 'map' in my manual, pulled the fuse out and replaced it immediately, entered the code and it's working fine, didn't even have to re set the radio stations.
So damn happy I didn't have to spend $$$$ buying a new unit. Thanks again !! |
#16 | ||
amazing how it just all of a sudden works again hey,
Why didn't FORD suggest this to me when i called them?????? |
