Old 27-09-2007, 03:48 PM   #1
sly
Sly like a G6
sly's Avatar
Default Have I Wrecked my IAC?
A few weeks ago I cleaned my throttle body and IAC. Due to the gas mixer I took the TB off the manifiold to do the job. Ever since, the revs drop too low when coasting or braking to a stop, they drop to 400 rpm or less once the revs get down to 1000 or so, it's an auto BTW. On petrol the revs usually recover after stumbling a bit and it idles OK, but it stalls on LPG almost every time, consequently I have to remember to switch to petrol coming up to intersections etc. Have done ECU reset but no difference.
It seems almost as if the IAC is not opening quickly enough or is sticky. Is this possible, can I test it? What sort of life should I expect from an IAC? Mine has 320,000km up.
Sleeper, anyone?
Old 28-09-2007, 12:23 AM   #2
daz_
Pulled the manifold off? Is there an air leak or something?
daz_ is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 05:51 AM   #3
au2sw
Blown 5L coming
au2sw's Avatar
are you 100% sure that you put everything back on exactly the way it came off? earth strap on, all vacum hoses still connected, LPG feed line still in position.....that sort of thing. I would honestly go over it thoroughly to make sure everything is on properly before thinking about changing the IAC.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 08:25 AM   #4
LPGUTE
LPGUTE's Avatar
is IAC the same as ISC? my car do the opposite to your the rev jump to 1800rpm.
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 08:30 AM   #5
FGII-XR6
FGII-XR6's Avatar
if you pulled the throttle body off did you replace the gasket? you may have a leak there with it running listen carefully see if you can hear a sucking noise. pour a bit of water over the throttle body area and see if there is any change, if there is it is a vacuum leak
Old 28-09-2007, 12:49 PM   #6
sly
Sly like a G6
sly's Avatar
Yes same thing.
Sleeper, anyone?
Old 28-09-2007, 12:51 PM   #7
sly
Sly like a G6
sly's Avatar
Double-checked connections etc yesterday, all good. Will do water test later today & see what happens.
Sleeper, anyone?
Old 28-09-2007, 10:07 PM   #8
sly
Sly like a G6
sly's Avatar
Read this thread http://www.fordforums.com.au/showthread.php?t=114646 and remembered that it's not switching over cleanly to LPG when cold now like it used to. It takes a bit of a rev on petrol before switching over otherwise it stalls when the gas kicks in. Maybe time to clean out the converter, it's done 4 years and about 130,000km, can't complain too much.
Sleeper, anyone?
Old 29-09-2007, 12:07 AM   #9
EX-Y494
EX-Y494's Avatar
The best way I know of if the ISC is working is to have the car running then unplug the ICS and if the car stalls it working if the car dosen't stall it not working.
Proud member of the All Ford Club of QLD
_____________________________________________
98 AU FORTE-Congo Green
C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter
BA front brakes, BA air box with pod
http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326
EX-Y494 is offline   Reply With Quote Multi-Quote with this Post
