Old 25-10-2007, 02:51 PM   #1
ECOJET
ECOJET's Avatar
Default Fairmont: EF or EL ?
hey guys
just after some advice as im a turning commodore man and am about to buy a fairmont.
Im going to keep it stock for a while, first plan is to convert it to straight gas, then maybe later add a turbo.
On the market they're roughly the same price so im just wondering, with the above plans in mind if they have any influence, should I buy an EF or an EL model? why?
ECOJET is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 03:19 PM   #2
bentles
bentles's Avatar
ef = coil pack
thats about the only functional difference mate.
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 03:23 PM   #3
Allen
You win again, gravity!!!
Allen's Avatar
EL's apart from being younger have a few minor differences.
Late EL 4.0's will have the hybrid AU head and rocker gear, Ghia's will have the speed sensitive steering. (or something like that)
The ELs had slightly revised rear suspension geometry as well IIRC.
Personally I think the EF grille looks tougher, but there isn't much between the two models, so just try and find the best example of either for your budget and you shouldn't have too many problems.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 04:05 PM   #4
ebgli
The EL handles alot better. Get and EF and an EL sideways and you will see what i mean!
ebgli is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 04:21 PM   #5
efI_Fairmont
efI_Fairmont's Avatar
G'day ecojet ,always nice to see another Ford convert
The difference between the two models is very small, but here goes:
*Slightly different factory alloys on EL's to the EF.
*EF have the coil pack - EL's went back to a distributor/coil (cost saving by Ford was one factor here)
*Rear Suspension is revised in the EF2 and further in the EL to improve handling.
*EF2 and EL Ghia's have the XR6 motor in them, as well as speed sensitive steering. EF Ghia's only get the standard 6. All standard Fairmont's EF or EL get the standard 6.
*Slightly different badges and instrument cluster (Font was changed)
*Colour coded power window buttons, a few other very minor cosmetic changes throughout.
That's about all I can think of. I reckon your best bet is to look at them all, and pick whichever one you can find with less km's and better condition, regardless of the model, since there is so little difference between them.
Good luck!
efI_Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 05:32 PM   #6
ef_classic
ef_classic's Avatar
I read that that was corrected in EF2?
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 05:37 PM   #7
tuffnc
aka SHY4D aka Patty
tuffnc's Avatar
can anyone elaborate on the speed sensitive steering?
tuffnc is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 06:09 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Basically it gets harder to turn the wheel the faster you go..... East to turn wheel when driving slow, harder when turning the wheel when going faster.
I would get an EL Fairmont, I have an EF Fairmont
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 07:01 PM   #9
tuffnc
aka SHY4D aka Patty
tuffnc's Avatar
cool. thank DRHEMI, i'll go try that now....lol
Old 25-10-2007, 07:13 PM   #10
andrewts
White Car Driver
andrewts's Avatar
The speed sensitive steering is insane! You can park the beast with your pinkie.
Good on you ecojet for giving the Fords a go, I hope your car serves you well.
andrewts is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 09:32 PM   #11
Gohan
[QUOTE=efI_Fairmont
*Good luck![/QUOTE]
ur tellin me my 1995 EF Monty has a XR6 motor in it? used: used:
i often wonderd somtimes when he revs above 3 grand sometimes
ELs and EFs not much in the body wise differant grilles, rims, the speed sensitive steering but try and get spare body parts u have to look high and low for them trust me i know i need a new bonnet no1 has them!! :evil3: :evil3:
Driven Lan Evo 9, Ex Cop AWD Magna, Ralliart Colt
Normal Driver Smashed UP! and GONE!
Gohan is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 09:53 PM   #12
Sorted
Sorted's Avatar
Originally Posted by Gohan
....but try and get spare body parts u have to look high and low for them trust me i know i need a new bonnet no1 has them!! :evil3: :evil3:....
Um I found heaps of Fairmont bonnets for you, what was wrong with them? look at your thread:---> http://www.fordforums.com.au/showthread.php?t=11192510
Tuned by DYNOMOTIVE
Old 25-10-2007, 09:56 PM   #13
FTe342
FTe342's Avatar
From Ford Falcon 2nd Edition by Ewan Kennedy the EFII suspension was improved but the EL was improved further again with different rate components, revised mounting points and retuning including different geometry in the front.
The EL also scored better glass tinting and sound proofing
Listen to Dr Hemi. I have an EL XR6 and love driving it
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 11:23 PM   #14
ECOJET
ECOJET's Avatar
the dizzy worries me a bit on the el! dizzys are so oldschool i feel like im going backwards!
but yeah, not totally fussy, whatever is in the best condition for the right price i'll snap up.
I reckon they're great value for money, ive had a statesman before and loved it and was going to get a vn/vp calais but to be honest im sick of the buick plus fairmonts have the same and more features as a calais and a better motor for sure.
Im hanging to get playing with that big straight six
Old 25-10-2007, 11:25 PM   #15
RED FGII
Formerly EL-351
RED FGII's Avatar
EL for sure mate
FORMALLY ORSM5L
RED FGII is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 07:24 AM   #16
Polyal
The 'Stihl' Man
Polyal's Avatar
EL Ghia, best e series you can get (of the normal models anyway). Leather, XR spec drivetrain, understated looks; only bummer is auto but if your keen then you can fix that.
Why would you stop at a normal Fairmont? E series are cheap as; dont put it in gas though; bit of a waste unless its a SVI system or something like that.
  • 1973 ZF Ford Fairlane
Old 26-10-2007, 09:00 AM   #17
XXRR-50
Formerly ORSMT-2
XXRR-50's Avatar
Stretch your budget to EFII/EL Ghia if you can. Definitely worth it. You'll get XR6 engine, 3.45 LSD, leather, premium sound etc.
I fitted SVI duel fuel to my EFII Ghia V8 and more than happy with it. No power loss, no backfiring, stalling etc and fuel consumption is better on gas than on petrol. Don't know how would SVI go if converted to straight gas. Has anyone done it on E-series?
Cheers,
Bud
FG XR50
Nitro, ZF 6-speed, Reversing Sensors, SSL's, Redback exhaust, J.W. Speaker LED kit
Previous cars:
'03 BA G220 Fairlane
'00 T2 TE50 #063(ORSMT-2)
'96 EFII Fairmont Ghia 5l V8(TOPGIA#2)
'03 BA Fairmont Ghia I6(TOPGIA#1)
'94 ED XR6(TKFRD-6)
'93 EB S-XR6
FOR SALE: ORSMT-2 NUMBER PLATES
XXRR-50 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 09:03 AM   #18
Polyal
The 'Stihl' Man
Polyal's Avatar
Cheers,
Bud
Ah yes apologies, EFII is not far behind the EL Moreso if you want a V8.
Old 26-10-2007, 09:12 AM   #19
Allen
Allen's Avatar
Don't let the EL's dizzy put you off, they only went back to the dizzy because it never worked 100% on the EF's... Although the EF's can be retrofitted with the better AU coil packs.
I agree with the other guys though, the Ghia is definatly worth the extra premium over the normal Fairmont.
Old 26-10-2007, 10:14 AM   #20
ECOJET
ECOJET's Avatar
i cant see a ghia for less than 6.. whereas my tight budget is up to 4 lol.
really i dont need a soundsystem i got my own better gear going in, the xr motor would be nice but will be nothing compared to what ill be building up, and the ls well im not gonna do any racing for a while..
and leather stuff i can always throw that in later on
Old 26-10-2007, 10:56 AM   #21
Polyal
The 'Stihl' Man
Polyal's Avatar
Then you might as well get a GLi mate
Old 26-10-2007, 11:11 AM   #22
raised by monkeys
raised by monkeys's Avatar
agreed
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 12:42 PM   #23
Sorted
Sorted's Avatar
(NSW) 1996 Ford EF Fairmont 6cyl Sedan $5,000
http://www.fordforums.com.au/showthread.php?t=11195355
(QLD) 1997 Ford EL Fairmont 6cyl Sedan $5,500
http://www.fordforums.com.au/showthread.php?t=11195454
(VIC) 1996 Ford EF Fairmont v8cyl Sedan (prob get it for $5,000)
http://www.fordforums.com.au/showthread.php?t=105462
(VIC) 1998 Ford EL Fairmont Ghia 6cyl Sedan ($5,500)
http://www.fordforums.com.au/showthread.php?t=11193221
Try looking in the cars for sale section here:- http://www.fordforums.com.au/forumdisplay.php?f=41
You can always offer them $4,000 and see what response you get – worth a try
eBay
(VIC) 1997 Ford Fairmont EL 6cyl $3,250
http://cgi.ebay.com.au/1997-Ford-Fai...QQcmdZViewItem
Tuned by DYNOMOTIVE
Old 26-10-2007, 05:27 PM   #24
RED FGII
Formerly EL-351
RED FGII's Avatar
that last link, broardford car sales, u can get some real bargains there :
FORMALLY ORSM5L
Old 26-10-2007, 05:37 PM   #25
ECOJET
ECOJET's Avatar
what u guys think about kays... i know these motors are tough as so where would you put the limit on with the reading, 240ish ?
Old 26-10-2007, 06:14 PM   #26
bentles
bentles's Avatar
well the car will run up to a million but it wont exactly be as new condition...
personally i wouldnt touch over 200,000 but thats because my car has 80,000
my last one with 240,000 was starting to get a bit rough around the edges for my liking
Old 26-10-2007, 07:03 PM   #27
Josh L
Laser Driver?
Josh L's Avatar
As bentles said... they will run up to and beyond a million.
Mine has 225,000 and is going not too bad albeit a couple of demons that have popped up. It all has to do with whether you are willing to spend the cash for rebuilding/reco'ing this or that.
Over 200,000 examples will keep you going with regular maintainence until you're ready to start getting nasty. They will handle a bit.
Mate of mine races speedway and bought an ex-taxi 4L which had done the clock once already... he reco'd it, whacked in some performance enhancing "drugs" (headers, zorst, aftermarket ecu and cam) and she's pulling like a train and well.
Is all really a money thing I suppose. So basically... if you go for something with over 200,000... treat it not so harshly until you are gonna be putting in the dough.
[/Ramble]
Josh.
The "Thrash Box"
'87 Laser TX3
Josh L is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 07:09 PM   #28
andrewts
White Car Driver
andrewts's Avatar
Well it depends how you treat it. If you drive like grampa, 1,000,000+. I'm not sure what to say if you flog it though. I would say that 300,000 before problems is a generous estimate, but my mate's brother drives an ED with 800,000km on the clock, he flogs the thing like mad and the engine has only been reco'd once.
Old 26-10-2007, 07:45 PM   #29
eb_5litre
It'll Buff Out.
I bought my EL Fairmont Ghia for $4000 with leather and 180,000k's from a caryard in Sydney.
When life hands you lemons, take them. Free stuff is awesome.
eb_5litre is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 11:24 PM   #30
ECOJET
ECOJET's Avatar
bargain.. they're definitely out there, just gotta be patient.
I guess i could settle for a basic gli, but i wouldnt mind some electrics, and i like things like cruise control, electric windows e.t.c.. im sucker for luxury items now
