When I go to start my car first thing in the morning, it usually takes a couple goes. It usually goes like this
engine turns over a couple times, nearly starts engine starts, runs for 5 secs then stalls engine starts, runs for 10 secs then stalls engine starts and runs fine its usually only the first start of the day when this happens, from then on its fine ![]() |
fuel or spark, whens the last time the plugs and lead were replaced
#3 | |||
That's Numberwang!!!
I had what sounds like a similar problem in my AU2 Ghia.
I ended up doing a reset and changed the battery and have not had the problem since... Hope it helps
www.aufalcon.com.au/only1 FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM Quote:
yeah try resetting the ECU 1st & see if that helps....
Walking with God
Reset the computer. Then if no joy, change the plugs.
Changing them is a 15-20 minute job and plugs are only $4 a pop for standard items. If still no joy, then I'd clean the ISC valve, then if still no joy, clean out the throttle body. If that doesn't help any, you could possibly change the fuel filter. Resetting of AU ECU http://www.fordforums.com.au/showpos...9&postcount=85 Cleaning ISC Valve http://www.fordforums.com.au/showpos...9&postcount=43 Cleaning Throttle Body http://www.fordforums.com.au/showpos...2&postcount=48 Changing Fuel Filter http://www.fordforums.com.au/showpos...3&postcount=37 All the best with it. GK
