Old 11-01-2008, 05:36 PM   #1
MGM
MGM's Avatar
Default is it the injectors?
hi guys, ive had a ticking sound coming from the engine bay for a while now, its real loud, i can hear it when driving next to a wall or barrier. the car still runs fine but i hate the sound. makes it sound crap
would it be injectors? is it bad to have them doing it?
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2008, 05:43 PM   #2
howesy
howesy's Avatar
Didn't look but if it's a v8 then more than likely the purge valve which is up in behind the near (passenger) side guard. Fords technical fix is to access the area and bend everything up and wrap a rag around it but be careful this is a highly technical ford skilled operation.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2008, 05:45 PM   #3
JOSH
JOSH's Avatar
yeah its the carbon cannister
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2008, 05:46 PM   #4
MGM
MGM's Avatar
nah its not an 8. just an xr6 ute <<. im not sure if the sound was there when i bought the car 8 or so months ago but i hate the sound. can it be the same problem being a 6?
Old 11-01-2008, 05:47 PM   #5
MGM
MGM's Avatar
what do i do about that? thanks for the quick replys
Old 11-01-2008, 05:48 PM   #6
JOSH
JOSH's Avatar
well it might be a lifter then, how long ago did you change the oil?
Old 11-01-2008, 05:58 PM   #7
MGM
MGM's Avatar
ive changed it twice in the last 8 months. last one was 2 weeks ago, had the sound before i changed it last time
Old 12-01-2008, 10:42 AM   #8
Burley
CRE.87V
yeh mate mine is the same......just had injectors serviced.....mech said it was lifters...replaced them all.....still there after 3000kms....changed fuel pressure regulator stopped for bit then came back after 4 hour trip....got told it could be the map sensor....still havent changed this
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2008, 11:41 AM   #9
MGM
MGM's Avatar
thanks mate, i want to find out what it is coz it sounds crap
Old 15-01-2008, 10:03 PM   #10
MGM
MGM's Avatar
got my extractors put on today and it seems to have made the ticking louder. when i looked under the car it kind of sounded like it was from the cat/gearbox to. unless the sound travels through the extractors somehow
Old 16-01-2008, 12:22 AM   #11
HLC
Audi S3
itll be an exhaust leak.
i have the same ticking. tightened all my header bolts. made it better for about 10 minutes, and now its even worse.
Old 16-01-2008, 09:35 AM   #12
GK
Walking with God
GK's Avatar
Extractors do make a ticking noise of their own.
Perhaps the noise you had previous to their installation was the timing chain. It is known to rattle, mine drives me nuts. The tensioner is hydraulic IIRC.
Try a different viscosity oil and see if that helps. I've tried 10W/40, 10W/50, 15W/50, all with varying degrees of success and next time I just may try a 10W/30. It's trial and error.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 16-01-2008, 06:55 PM   #13
MGM
MGM's Avatar
thanks mate, i was thinking on the way to work today tha it could possible be valve clearances?my car only starts ticking when its getting warm then it does it all the time. but not when cold
Old 16-01-2008, 07:08 PM   #14
GK
Walking with God
GK's Avatar
There's no valve clearances to set, the tappets are hydraulic also.
GK
Now gone!
On LPG
Old 16-01-2008, 07:31 PM   #15
Burley
CRE.87V
yeh mate mine does the same....only when its warm to..not when its cold....put the screwdriver to ur fuel rail....mine comes from this area....mine have gotten louder since the extractors got installed...pacey comp header....4480????
Old 16-01-2008, 10:00 PM   #16
MGM
MGM's Avatar
i got the 4499's cheap off a member on here. the extractors were louder yesterday with the ticking than today. but i thought it was mabey the injectors as it didnt do it when i bought the car (i think)
Old 16-01-2008, 10:06 PM   #17
kcej
2mny projects 2 lttl time
Have you tried to isolate the noise with the old "long screwdriver handle pressed to your ear, then touch various parts" trick?
It can be staggering how well that works
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2008, 06:05 PM   #18
MGM
MGM's Avatar
no i havnt coz ive never heard of doing that but il give it a go tomorro. thanks mate
