Formerly MR BAXR6t
Hey all
Could somebody please give me an insight to what this noise could be?? It basically is rattle/grind when taking car is at low revs in any gear, i can feel the vibration through the gear stick and is quite loud. Once it gets past say 1200-1400 rpm it goes. What could this be?? Cheers Frank
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
does it do it in neutral with the clutch pedal out as well or not, also, does it make any difference what gear you are in. Also, any change in noise with the clutch depressed?
#3 | |||
Formerly MR BAXR6t
can u give more information on the rattle/grind?
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
64 Deluxe 4 door
![]() Join Date: Jun 2007
clutch throw out bearing???
or a broken gear
XM Deluxe FG XR50 BA Pursuit Ute |
yep another vote here for the throwout/spigot bearing
Formerly MR BAXR6t
Is that expensive to fix???
a little bit expensive i guess, either motor or gearbox has to come out
