Old 31-01-2008, 01:08 AM   #1
kcej
2mny projects 2 lttl time
Default Injector changeover time?
I have a manual, good toolkit, good? mechanical skills.......
How long is it likely to take to remove and replace all six injectors in an AU, and also to remove and replace anything else thats in the way?
Is there anything I should know thats not in the manual,.... tips, tricks, etc.?
Thanks Keith
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2008, 03:27 PM   #2
FS5
a couple of hours i'd reckon.
the only tip i can give is once you have the fuel rail off ,change one injector at a time to make sure you plug the right lead back on .also be careful when your removing the little retaining clips off the wiring plug.there easy to drop and hard to find...
i'm guessing you have new rubber o rings to fit on your new injectors,if you haven't i'd buy some new ones.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
