Old 01-06-2008, 10:32 PM   #1
MotherNatureVer2
Default Quick question
Hi guys,
Posting for a mate. He is having problems with his AUII heater. It seems that everything is working apart from the knob that changes the area of heating eg: it wont move up to the windscreen vents, nor to the feet for that matter.
It will change temp and will turn on & off. There is a mouse & rat plague (yes were very rural out here) and there seems to be a wire just in front of the headlights that seem to have been nibbled.
His speedo seems to be not functioning as well. Im assuming these two problems are purely coincidental (well I hope they are). If not the rats must die a slow & painful death :P
Any ideas ????????
MotherNatureVer2 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2008, 10:56 PM   #2
Stav
Smile
Stav's Avatar
A very common problem is that the air intake at the passengers feet sucks up paper or a plastic bag and stops the air going through. To check this have the car off and stick your hand up the vent and feel for paper or plastic.If thats the problem then pull it out.
The knob controls a vacum air switch /solenoid which moves the flap to windscreen,floor etc. Either its losing vacuum/jammed or the switch is stuffed.Try the easy troubleshooting first.
Old 01-06-2008, 10:59 PM   #3
superroo
You can't stop the signal
superroo's Avatar
The area of heating control is changed by a vacuum. The engine pulls a vacuum in the system and that then pull various vents open and close.
I would say his problem will be on the back of the heater control it self. The main line that supplies vacuum has come off the control. This has happened to me a few times due to taking the center fascia on and off repeatedly.
To check that it is the problem, you need to
1. Pull the glove box out. Open the glove box and disengage the limit pins by pulling the sides of the glove box inwards. Lower the glove box and firmly lift the right hand side corned to disengage the hinges. Maneuver the glove box from the dash
2.Disconnect the vacuum supply hose from the T piece (red circle) in the vacuum hose harness. Disconnect the 8 port vacuum hose (green circle) harness connect beneath the air intake duct.
If a suction can be heard (it is very evident, easy to hear) then the problem is in behind the center fascia, if no suction is hear, then the problem will be in the engines vacuum lines and vacuum tank.
Yeah your right mother nature, the two problems are coincidental. And i not sure what wire you're on about either.
Old 02-06-2008, 08:07 AM   #4
MotherNatureVer2
Thanks heaps for the info guys. I will be seeing this car again on the weekend and will check it all out.
The wires are actually a part of the loom that is really behind the headlight. (re reading is a good thing, bad description in the first place). I traced this smallish part of the loom to go back towards the firewall on the passenger side but it is of cause connected to the main loom that goes along the front of the car. This part of the loom has a connector on it & there are two almost identical mini looms that have these connectors, only one is nibbled. The wires are not eaten through but needing more one of those shrink wrap covers to keep it protected. Was a bit curious as to where it belonged. Might be easier if I get some pics next time I am with the car.
Old 02-06-2008, 08:44 AM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Dont remind me... i just left that sort of area and now have the buggers in my house :
Old 02-06-2008, 09:19 AM   #6
NC1183
NC1183's Avatar
Oh, whats wrong with Moree. Its a fun happy country town, thats dying a slow death, with a sky high crime rate and roads that make all the so called crap roads in Sydney look like a F1 track
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2008, 11:20 AM   #7
InfernoSR
InfernoSR's Avatar
Um... i have plenty more to add... but it would take up more pages
