Old 04-06-2008, 10:54 PM   #1
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Default Squeaking rear
Hi all
I got my XR lowered when i got my rims, and now there is a slight speak noise coming from the drivers side rear spring/shock. I took it back and asked the tyre mob i bought it off and they told me it was some kind of plate?? or something like that moving around at the top of the shock/spring and as it gets worse it will start to knock?
Apparantly its only a genuine part bout $105. Does anyone have any idea wat this could be and if its a DIY job?
Cheers Frank
Current car
94 ED Fairmont 5L in Burgundy
Fords ive owned-
2010 FG XR6 5 speed auto in Mystic
81 XD S-Pac 302c 4sp manual
78 Yellow TE Cortina Wagon 4.1L
92 Green EB Fairmont GT replica
01 Black AU XR8 II Manual
04 Rapid BAII XR6T 220rwkw
04 Mandarin BA XR6T 247rwkw
07 BF II XR6T 385rwkw
1980 ZJ Fairlane 302c
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2008, 12:34 AM   #2
blueoval
Critical Thinker
blueoval's Avatar
Frank,
I personally wouldnt buy yet. I reckon it may be the rubber cap that may sit on or under the spring that needs a bit of grease chucked in between. Try that before you spend more dough first. Get them to do the grease option to start with, if that fails then try the plate as suggested.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2008, 08:16 AM   #3
RG
Back to Le Frenchy
RG's Avatar
Top IRS shock mount is what he is on about. A known problem and they fail at about the 50k mark. They are only a genuine part but $105 is a bit rich, I got my last pair for $77 each and that was only a couple of months ago. It is a fairly involved job that requires two people to do it, if you paid for springs to be fitted I think you'd be best off getting these fitted too.
Word of advice too, Ford changed the design slightly from the original units so now the shock shaft comes through a bit further. To rectify this (it causes knocking) all you need to do is fit two standard thickness washers underneath the rubber cup at the top of the mount. Makes the rear end feel a hell of a lot tighter too.
