Old 31-07-2008, 08:38 AM   #1
InfernoSR
Sales Representative
InfernoSR's Avatar
Default BA steering column in AU
I am planning on converting my dash to a BA XR dash... do i need to replace the steering column to a BA unit, or will a telescopic/tilt AU unit still be ok... as i am unsure if they are the same.
Old 31-07-2008, 09:01 AM   #2
InfernoSR
InfernoSR's Avatar
Default BA handbrake in AU
How much of the BA handbrake system is the same as the AU unit? is it just the handpiece thats different?
Old 31-07-2008, 06:50 PM   #3
b2tf
not here much anymore
b2tf's Avatar
merged the handbrake and steering column threads
the BA handbrake setup operates in a different way to an AU
2024 F150 XLT
Old 31-07-2008, 07:45 PM   #4
InfernoSR
InfernoSR's Avatar
Cheers more the merge mate...
In order to have the right look with the centre console, i want to use the BA handbrake... any advise on how to get it to work?
Old 31-07-2008, 08:12 PM   #5
b2tf
b2tf's Avatar
ive never looked at one in any great detail but id assume that the best way to do it would be to graft the BA handle onto the AU mechanism
2024 F150 XLT
Old 31-07-2008, 08:18 PM   #6
aye you
The Origional, The Best
aye you's Avatar
would probably be the best idea mate
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2008, 08:45 PM   #7
EvilChief
Boost Addict
the Au handbrake adjuster is under the car, which is u-cable style setup, whereas the AU adjuster is at the handbrake lever itself. the BA cover is not removeable, whereas the AU one is for adustment. having said that the handbrake shoe setup is pretty much the same, which would mean you could convert the entire system to BA, or use the AU lever with BA cover, you just need to accomodate for the adjustment under the cover
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 31-07-2008, 09:01 PM   #8
InfernoSR
InfernoSR's Avatar
Well incase some of you dont know.. i actually have a foot mounted hand brake system... so i need to convert it from that to something else... starting to think about adapting the BA unit...
Old 31-07-2008, 09:44 PM   #9
EvilChief
Boost Addict
lol ... u will def need a complete BA unit (inc cables all the way back to the shoes). i am not sure if ur floor pan will have the provisions for the hand brake lever assembly, i would assume so thou. would be silly to have diff floor pans for diff models
N12 Pulsar - sold
Old 31-07-2008, 10:45 PM   #10
InfernoSR
InfernoSR's Avatar
Cheers guys... Looks like its the BA stuff for sure
Old 31-07-2008, 11:49 PM   #11
superroo
You can't stop the signal
superroo's Avatar
Hand brakes are different between AU and BA.
I can tell you the cable is different as I’ve got a BA diff in my AU. Differences are in where the cable attaches to the diff it's self. The brackets are in different locations, but it's nothing a large hose clamp can't fix
As for the handle, JC looked into it so he knows the differences for sure, but it relates to the AU handle is bolted to the tunnel, and the BA is bolted to the floor ban. Or some difference like that. Either way, he decided against the conversion on his car.
