Old 25-08-2008, 06:04 PM   #1
fipcee
not so stock
fipcee's Avatar
Talking Painful whine developed,(and no it's not the wife)
I feel that I may have a more major concern at the moment, the car has developed a loud "whine" in the last 2 weeks : . Doesn't sound like diff as it appears to be coming from towards the front, guessing auto??? I am also "feeling" some vibrations through the foot rest. I can put the car in neutral when driving along and the noise is still there. When in gear and slowing down the noise eases off until it drops to 2nd gear and then I can hear it pick up again, slightly, before quietening off again. Going down hill with no throttle pressure it gets louder. Finally every now and then I hear a "humm" from somewhere near the glove box : I checked the handbook thinking that maybe I need to top up the transmission fluid but apparently it is a sealed unit. Had a full flush done approx 15000k's ago, car has done 88000k's and has not been flogged since I purchased it 3 1/2 yrs ago, I have done 30000k's in it in this time. I realise that it is hard to do a diagnosis but any suggestions on likely cause and fixes will be muchly appreciated. Thanks
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors.
Next mods: extractors
fipcee is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 06:35 PM   #2
fordlova8
FEARsome 429
fordlova8's Avatar
The whine could be the transmisson oil pump. I had the same thing, if it is the same thing. Happen to my XR6 EL and i was told that you can spend big $$$ just to get rid of a noise. Does it fade as the car warms up?
Live by the Ford
Die by the Ford!
1978 429 XC Fairmont GXHELL.
fordlova8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 06:53 PM   #3
fipcee
not so stock
fipcee's Avatar
Hiya Daveo, no mate it doesn't seem to quieten down, must admit that I have been driving it sparingly at the moment until I get a mate to have a look at it next weekend. Thanks for your post mate
Old 25-08-2008, 07:39 PM   #4
XR6Stu
wheel bearing, or possobly diff. I replaced my diff centre before christmas, and before it was replaced gave me the inmpression it was coming from up front, as the noise travels along the tailshaft into the gearbox.
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 09:17 PM   #5
fipcee
not so stock
fipcee's Avatar
Certain it's not wheel bearings as they were all checked 3 months ago when I had the suspension fitted and it doesn't make sense when it comes to the whine change when the car shifts down gears. I'm still leaning towards gearbox, though what you say about the noise from the diff travelling makes sense XR6Stu. What's the easiest road test to perform to see if it is diff or transmission?? Thanks for your input Stu
Old 26-08-2008, 09:20 AM   #6
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
What happens when you place it in neutral and roll down a hill? noise get louder as your speed increases?
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2008, 02:51 PM   #7
fipcee
not so stock
fipcee's Avatar
G'day mate, no the noise remains constant, actually sounds like it wants to "go harder" if that make sense but it doesn't, sort of like it hits "peak revs". Hope that make sense
Old 26-08-2008, 03:22 PM   #8
fordlova8
FEARsome 429
fordlova8's Avatar
If the pitch changes ie gets higher as it goes through the gears i would say its the transmisson oil pump for sure.
I liken mine to having a super charger, as it has sort of a whistle with the whine.
that changes pitch with higher revs. It has been like that for about 4 months.
Good luck.
Live by the Ford
Die by the Ford!
