Custom e-series owner
hey all, i am putting an AU engine in my ea and am going to fit the AU thermostat housing but see the problem is that the ea-ef have a temp sensor and a coolant temp sensor in the housing, where the AU one has nothing.
i know there is the sonsor at the back of the head but thats just for the gauge is it not? see the ea-ef have one for just the gauge(that has one wire) and one that goes back to the ecu(has 2 wires). so where is the coolant temp sensor on the AU? any help would be great.. cheers shaun
88 ea falcon fresh paint, 20 inch chrome wheels, ed xr front, scorcher body kit, ef/el mirrors and door trims, UPC 330mm twin piston big brakes, manual, front adjustable coil overs, 2.5 inch exhaust, twin thermos etc etc **atomic built 660kw AU engine being fitted**
#2 | ||||
Back to Le Frenchy
cheers for that
#4 | |||
Walking with God
Just be sure to check. GK
AULTD
I thought the sensor in the header tank was for coolant level not temperature!!!!
#6 | |||
Boost Addict
spot on that sensor is just water level on the up series models, such as fairmonts and XRs the sensor at the back of the head is the head temperature sensor, which is teh ecu sensors, the ecu generates a signal for the gauge. gauge doesn work = thermos dont work = overheating what wiring loom and ecu are you going to use? more so what dash are u using. id just fit and ef thermostat housing and fit and ea dash sensor, and the rest use the au loom.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#7 | |||
it was just that the AU looks allot neater without the sensors in it..:(
Walking with God
I'll correct my earlier post, as I didn't properly read the question. Serves me right! LOL!
The coolant level sensor was on the S1 header tank/coolant tank/reservoir. The other guys are correct in saying the coolant temp sensor is behind the engine at the firewall. Cheers, GK
what about BA
anyone knows where is coolent sensor
Flairs - Truckers Delight
hi motojazz
this is the AU section and a 3 year old thread at that. you'll have better luck posting in the BA section in your very own new thread!
#12 | ||
B-series is in a similar position .. as the head is a bit bigger ... the sensor is tucked around a bit further.
Look, a shinny THING!
I have an AU ser 2 and there is no sencer in the top tank but my warning light is flashing!
Does this mean the sencer at the back of the head is falty? |
#14 | ||
Bugger!
Maybe. Get a sparky to have a look for you; the AUs do occasionally break those sensors.
*edit* Hang on, which warning light? Temp or coolant level?
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 ![]() |
#15 | ||
Lol its ok I found the problem and here is the fix;
Between the battery and the suspension tower you will find a round plug, This plug is used on Series 1 AU for the coolant level sensor! Ford used a loop plug to cancel this but the earth goes bad so it needs to be upgraded! Find the Yellow with Red stripe wire and make a connection to the Negative on the Battery. On the series 3 this was deleted! If you want to a Series 1 bottle with sensor can be connected if you can be bothered .... ![]() ![]() ![]() |
#16 | ||
How do I unclip, undo the 2 wires on the sensor. I can hardly reach it behind the head.
Can I short it out to check if fans come on? My problem is I overheat at lights and steep hills. Both fans come on at start with A/C on. (thanks someone) |
#17 | |||
Sounds like you may have a pump falure. sometimes the impelor can rust its vains down to blades just like a vegi chopper. this can happen when water is used in place of coolent! I have had this happen on a v6 I once had! Ok when moving but overheats easy for no good reason. Oh and check your thurmostat it could be stuck , if so replace it! Last edited by DriveArealCar; 16-12-2011 at 12:56 AM. |
#18 | |||
Ok the sensor in the header tank is a coolent level sensor. The sensor in the back of the head is the temprator sensor, and the ecm sends the relivant info to the instraments. So if you need 2 the easy way is to use the ef thermostat housing to add the second sensor |
#19 | ||
F6 Typhn
Hi
I have a series 3. Fairmont ghia au but have no sensor in the overflow bottle? Is this normal? My mates series 1 Fairmont ghua has a sensor in the overflow bottle? Cheers |
#20 | ||
F6 Typhn
Hi
