Old 03-01-2009, 03:50 PM   #1
1falconer1
Default Clattering noise from engine bay
1999 Au with 170k on the donk.
When starting from cold there is sometimes a clattering from under the bonnet. Sounds loud from inside the car but is barely noticeable outside or from under the bonnet. The noise lasts for about 20 seconds or so and peters out. It is definately engine related as it changes pitch when the engine speeds up when the box is in neutral. Happens only in the mornings when the temperature is lower and the lower the temperature the longer the noise lasts.
Belt?
Any ideas?
1falconer1 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2009, 04:16 PM   #2
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
sounds like it could be a valve lifter tapping..............the valve lifters are sticky when the engine (and oil) is cold......you can get an additive to put in the engine oil that usually does the trick.....
Old 03-01-2009, 07:26 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Try using a lighter oil, as in a 10W 30. The noise goes away when full oil pressure has been achieved, mine used to do the same, especially on colder mornings, as it takes longer to get all the oil around the engine and pressurised. Changing to 10W 30 helped mine a lot.
MD Mondeo - For the family
NP Pajero - For the adventure
