I've noticed a 'whooshing' sound that appears to come from the cat when I accelerate. Is that normal? It is a magnaflow cat. I just had headers fitted so there shouldn't be any leaks, plus it did it before but I really didn't take any notice.
Are there any vacuum hoses on the drivers side that may have come loose that would make the sound I'm describing under throttle? Cheers. |
i think you might have Whoosha trapped in your cat
My '00 AU Ghia which has extractors and a 3 inch system makes a similar noise when I initially apply more than gentle pedal though I haven't yet been able to pinpoint the source except that it seems to come from under the front of the car. I have checked under bonnet plumbing. Any clues greatly appreciated. Ray.
#4 | |||
Walking with God
Hope you both work out what the noise is. Probably more noise (less restriction) from your freer flowing exhaust. GK
#5 | ||||
Back to Le Frenchy
![]() Oh my. Is it the standard cat or an aftermarket item?
Aftermarket magnaflow.
#7 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
well i developed the same noise the day after i got my high flo cat installed... it sounds yuck but i think its a leak as it wasnt like that when i left the shop
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
#9 | |||
ok... well apparently its my 'idle bearings' i was told at the exhaust place. we got under the car on the hoist with it on and i can 100% say that its not the exhaust making the noise, they thougt it might be the fuel pump or the bearings but after they heard the noise coming frm under the bonnet they seem to be sure its the idle bearings
