BA Mk2 Fairmont
Im going to change the pads and rotors tomorrow for my AUII Forte. Im going to get Benidx Ultra Premium pads, but I am not sure which rotors to get. What the difference between slotted and standard rotors?
Im tossing up between DBA and RDA - which one should I go for? Cheers |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Both are Ok for street use just go with the cheaper one
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
BA Mk2 Fairmont
Do you know which type/model RDA standard rotors I need for my falcon?
CANT !!!!!!!!
Standard rotors are usually of a lower quality for a start, and ive found that they tend to warp easily,
![]() So spend the little extra and go the slotted, you will notice the differance no matter which brand you choose. ![]() Though ive had a good run out of the DBA :eclipsee_ Cheers
-BA XR8 Ute- Better to be late, than VERY LATE !!!! ![]() YEAH HA !!!!!!!! ![]() |
Walking with God
Slotted rotors are said to be better for clearing away the brake dust. I'd certainly go slotteds. I personally use RDA gear and have found it to be very good.
If you do buy them, they'll be cheaper than DBA gear, you'll need to paint the "hat" of the disc before fitting. This is good, as it allows you the choice of colour in painting. Some guys colour code them to the car, I just went for the grey colour myself. Each to their own though! A good opportunity to paint your calipers also I'd reckon. I went red, but many guys here like to paint them a Ford blue, or even colour code them also. De-rusting and painting rotors http://www.fordforums.com.au/showpos...2&postcount=68 * Note - the derusting will need to be done on RDA gear if you put them on without painting them. LOL! I found out the hard way. Cheers, GK
#6 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
UK
