All Bran = Regular Member
A little project I completed this evening:-
1.Get a 100mm-90mm PVC adapter from your local plumbing supplies or hardware ![]() While you're there get a 90mm mesh cap ![]() 2.Remove airbox from vehicle (remove lid, remove snorkel, undo 3 x 10mm bolts) 3. Mark airbox at appropriate location. Cut away any strengthening ribs that will be in the way. ![]() 4. Cut out 90mm circle - I drilled the holes and then used a stanley knife to cut between the holes - BE CAREFUL - Stanley knives are SHARP!! ![]() 5. Use a half round file to tidy the opening so that the 90mm end of the adapter is a neat fit. ![]() 6. Fit adapter so that the 100mm end is inside the airbox and the adapter is pushed hard up to the tapered section. ![]() ![]() ![]() 7. Fit mesh cap onto 90mm external end of adapter. ![]() ![]() 8. For ease of airbox installation, remove the mesh end and push adapter far enough into the airbox so that the lower 10mm bolt is accessible. ![]() 9. When airbox bolts are tight and snorkel fitted, refit mesh end to adapter. ![]() 10. Fit air cleaner element and airbox lid. ![]() Jobs done ![]() The mesh end holds the adapter in place so there is no need for glue, plastic welding etc. Tools:- 10mm socket/ratchet, pencil, saw, Stanley knife, drill, drill bit, half round file (coarse). Time:- Took me a couple of hours as I had to double check as well as take pics. Would only take an hour using this guide. Comment:- Believe it or not, this cheap (less than $10) and easy mod does make a difference. I only went around the block but there is noticeable improvement in throttle response. Last edited by ronwest; 08-06-2009 at 11:46 PM. |
FG GT 5.4 w/ additions!
Cool,
Great work, You could perhaps up the total cost to $15 and paint it black though! ![]() |
#3 | |||
Actually I wasn't going to do it today so didn't have black paint on hand but when I looked at it I thought "what the heck" and got into it... |
Nice one bro! ;)
well done!
The Monty
hey thats a good idea, Notice any inprovement in accel or anything else?
like the idea nice and cheap yet effective and not over the top i like the idea of painting it too brad` |
Finished! ;)
#8 | |||
Main reason I got to thinking about it is that I'm off up north in a few weeks. I'll be using a car bra which you'd expect would cut down the air flow. I think that with a bit of fiddling I can run a bend and pipe off the adapter and source some more cold air a bit lower. I'll play with it over the next week or two. |
I dis the same http://www.fordforums.com.au/showpos...4&postcount=13 and it works well
[SIGPIC][/SIGPIC]
AFF Whore
If only i'd seen this thread before I butchered my airbox with an ugly rectangle cut out :(
The Monty
haha i started a new thread the night before u posted this one, asking about dual intakes and well urs is the cheapest and still effective one i came across looks the bit too as i mentioned earlier, can u get the adapter at bigger length so it sits behind the light a little more or is it one size only
#12 | |||
I've got a few pvc bits and pieces down the shed, later on I'll see if I've got the bits and take a pic. |
The only joiner I've got has an external thread at one end but it will do to demonstrate - one end for the pipe, the other end to the adapter
![]() If you really want to ram some air in, you can make up this little beauty. Simply remove the headlight and poke it through... ![]() |
#14 | ||
I've done something very similar with my Territory though it extends further and goes well outside the engine bay and under the headlight.
I have one of those threaded connections fixed inside the airbox and carry a screw on cap in the car should I ever want (or need) to drive through really deep water. Just screw it on on to close this 2nd inlet and it's back to the standard over-the-radiator inlet with its greater fording depth.
#15 | ||
Critical Thinker
not a bad little mod. Thanks for the tutorial.
Personally for me I wont need this, but if anyone has an alternate mod for a CAI coming from the front bumper I would be interested to see it.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#16 | ||
Irregular member
That's great, I'm gonna have to have a go at this sometime soon. Thanks a lot for posting that up mate.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
#17 | ||
im working on a air intake at the moment which consists of completely cutting the front wall of the airbox and extending the box towards the xr headlights, should work well
#18 | ||
My final pic for air rams... just gotta cut a hole in the bonnet and she's a goer...
#19 | ||
Critical Thinker
![]() fwully shick moit
#20 | |||
#21 | ||
The Monty
now u can finally see over those 4x4s to see whats ahead of u haha
#22 | ||
Dont laugh, I've seen it done. Again, Shepparton never surprises me when it comes to cheap car mods. Just not that high.
#23 | |||
Lost Boost Gained Class
thats a good idea i might try something like that ![]()
2006 BF Fairmont Ghia
2001 AU Falcon |
#25 | ||
What Wheelspin?
geez guys. for the .25 of a killowatt that all these airbox/intake mods would give you it hardly seems worth it.
id actually be surpirsed if this made more power. my car actaully made less power on the dyno without the airbox and just 3 inch pipe. it leaned out the mixture, and lost power. maybe with a custom tune u might gain a bit. save ur time and money and buy and cam/chip.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
#26 | ||
what sort of cam or chip would you get for $10 :togo:
#27 | ||
What Wheelspin?
none?
#28 | ||
What Wheelspin?
how many times have u had a falcon 6 on a dyno with different intake setups back to back???? and seen power, a/f, tourqe changes????
gut loads of air + no tune, doesnt mean more power. simple.
#29 | ||
Irregular member
We can always try it and plug the hole if it doesn't work out. G&D sell something for several hundred that rams more air in from behind the headlight and has people claiming it's worth it.
My concern is, as well as with electric inline "superchargers", will the engine's computer simply adjust somehow to the detected change of incoming air and cancel out any positive effect in time?
#30 | ||
I am so going to do this. ... It would apply for all airboxes. (except EA to ED Inline 6) EF to even FG...
