Old 13-06-2009, 06:31 AM   #1
madas
Default AU111 seat belt
I trying to replace a rear seat belt but finding it hard to get to the anchour points. Any tips on getting the belt out? Thanks
madas is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2009, 07:21 PM   #2
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
The centre one is under the parcel shelf and the outer ones are behind the c pillars plastic
Other end is under the seat cushion
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2009, 06:03 AM   #3
madas
thanks
the ones under the C pillar plastic are not the easiest to get to. I'll just take it to the shop and get them to change it
Old 15-06-2009, 07:48 PM   #4
Jastel
Take off rubber door seal that edges against the plastic, and then pull it off, just held in by spring clips
Very easy, then undo seat belt, need torx bit to undo
The middle one is the harder one
