Old 02-07-2009, 03:54 PM   #1
bartsau
bartsau's Avatar
Default Pedal Box Dramas
Hi there guys just wondering if someone can help me out.
Trying to remove a manual pedal box out of a ute. Can't get the brake pedal arm seperated to be able to manipulate the pedal box around and out over the brake master cylinder arm thingy.
Thanks in advance for any help.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2009, 03:56 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
taken off the brake light switch and such?
Old 02-07-2009, 09:26 PM   #3
bartsau
bartsau's Avatar
yep brake light switch and clutch cable and connection from brake pedal to the booster.
oh and the switch connected to the clutch pedal.
Just can't get the box out and thinking i need to get the brake pedal arm off the box assembly. I have removed the clip connceting this arm but can't work out why i can't dissconect this arm it is still locked in place somehow.
Wagon Build
Toy Car Build
Old 02-07-2009, 10:23 PM   #4
philstoj
philstoj's Avatar
You have to take the clips off the shaft at the sides of the pedal box, then you need to push the shaft from the pass side end (from left to right) so it clears the pedal box and then you pull it out from underneath, (from right to left) the shaft doesnt push all the way through, you must go one way then pull it out of the other end.
Old 02-07-2009, 11:28 PM   #5
bartsau
bartsau's Avatar
Thanks for that i will give it a crack tomorrow.
Wagon Build
Toy Car Build
