Old 19-08-2009, 01:37 PM   #1
White_sr_taxi
Default steering wheel?
this may sound silly, but do late model e series share the same steering wheel as an au? i took el (?) xr6 for a test drive today and saw that the wheel and airbag looked simmilar. and can ford factory cruse control be installed in a car that didn't come with it? is it plug and play? Cheers
White_sr_taxi is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2009, 02:45 PM   #2
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Cruise control is plug and play, but you need to plug a bunch of stuff in. Anyone (even me) can do it... There's a good tutorial on fordmods.com.
Pretty sure an AU wheel will fit an E-series too.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2009, 03:16 PM   #3
Jack91
Jack91's Avatar
If you are planning on putting cruise into an EL, Im in Hobart too and have done it myself, chuck me a PM if you need a hand, more than happy to help.
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2009, 03:19 PM   #4
Jack91
Jack91's Avatar
http://www.fordmods.com/documents.php?d=11
Said tutorial. Cruise is a LOT harder to put into a non abs car, not impossible but a big effort.
Old 19-08-2009, 03:27 PM   #5
White_sr_taxi
cheers for the quick reply, i was wondering about putting cruse in the AU, i should have been little clearer sorry guys. but from whats been said even for the au its quite simple (so im told :S) is there any issues buying an el/f steering wheel for an au?
Old 19-08-2009, 10:52 PM   #6
last fairlane
last fairlane's Avatar
Wink EF Wheel
Hi all I put an EF wheel on my AU Fairmont
they use the same mounts and airbag but the bolts are "torx" on the AU and the cruise and stereo buttons all fitted
so no probs with that swap
John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2009, 08:53 AM   #7
White_sr_taxi
thanks for clarifying this for me, putting that info to good use now i can say good by to the daggy stock wheel now
