Old 22-08-2009, 10:22 AM   #1
LukeyST
ST fan
LukeyST's Avatar
Question Rocker gear bolts torque settings? (VCT I6)
Gday,
Does anyone know what torque the bolts holding the rocker gear down should be tightened too? And is there a special pattern for the order to tighten them down? I'm going to do my lifters today, but the i'm not touching a thing till i have this info.
The car is a series III xr6 VCT, im not sure if it being VCT would make a difference compared to HP?
Thanks.
2013 Focus ST in TANGERINE SCREAM
2003 Focus Zetec in COLORADO RED
LukeyST is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2009, 10:41 AM   #2
FreddyDUZ747
FreddyDUZ747's Avatar
Rocker arm shaft pedestal bolts=25nm
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2009, 10:56 AM   #3
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
There is - our tech section has the torque setting and the sequence - it's always a good place to start.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2009, 01:23 PM   #4
LukeyST
ST fan
LukeyST's Avatar
Wow some great info there, thanks guys i appreciate it!
Old 23-08-2009, 01:49 PM   #5
LukeyST
ST fan
LukeyST's Avatar
Ok another quick question,
I put the new lifters in, used some good assembly lube in the process so everything was nice and slippery when it went back in.
When i first turned it over it made a horrible noise for about 2 seconds (which i expected) but then they all seemed to settle besides what sounds like just the one lifter towards the rear of the engine. I had it running (just at idle) for about 3 minutes and it didnt go away. I revved it up to about 2500rpm and it seemed to quieten it but it came back again at idle. At this point i just switched her off in fear of doing some damage :(
Should i give it some revs and hold it to build some pressure or something??
I have oil and a filter to do a change, should i change the oil now and see if it fixes it?? The oil in it is about 10,000km old, if that. The new oil i have is Penrite 10w-50 which was recommended to me for the AU i6.
Any help greatly appreciated.
Old 23-08-2009, 03:22 PM   #6
LukeyST
ST fan
LukeyST's Avatar
All fixed.
Got some advice elsewhere to take it for a run and keep it in the mid range of the revs. So i changed the oil (had too, as i already had the engine flush in it) and took it for a run. As good as dead quiet at idle, slight tick at 2000-2500rpm (but still better than before) and above that engine noise drowns anything minor out.
I was told that the i'd still have air to be bled in the new lifters, and this seems to be the case as its still improving.
