Old 03-09-2009, 06:41 PM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default high idle
Hey All,
I am having a problem with my XR6, at idle it is sitting at 2000rpm.
would a stuck ISC cause this?
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2009, 07:11 PM   #2
JMO
JMO's Avatar
Possibly, but I doubt it. I'd be looking for a vacuum leak or at the throttle position sensor.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2009, 11:49 AM   #3
Stattic
Stattic's Avatar
wow i thought my 950rpm was high lol thats crazy
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2009, 01:59 PM   #4
JC
JC's Avatar
Originally Posted by REDAUXR6II
Hey All,
Yes, it can. This happened on my EL (not much difference between EL and AU ISCs). A new ISC fixed it. If the ISC keeps the revs low, cleaning can help, but if it's keeping the revs high, only a new one will fix it, from my experience.
Ford Performance Club ACT
Old 06-09-2009, 01:38 PM   #5
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
why is your idle so high?
i have a wade 1521a cam, and my idle is smack on 750rpm. no hunting. its all in the tune.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2009, 01:19 PM   #6
REDAUXR6II
REDAUXR6II's Avatar
tried cleaning it but not luck a new one is on its way, ill post up what i get after it goes onto the car
Old 12-09-2009, 02:28 PM   #7
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
lol mine sits around 1,000RPM and mines a stocker besides the Air intake
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2009, 11:09 PM   #8
Stattic
Stattic's Avatar
wish i could tell you lol
cant afford to get it retuned... and its strange cuz when i first got there it was sitting at like 750-800 perfectly and then after a while it just started stalling so they gradually upped it
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 22-09-2009, 12:37 PM   #9
REDAUXR6II
REDAUXR6II's Avatar
well i have replaced the IAC but no luck, the car still idles at 2000 rpm, i have tried unplugging the IAC and starting the car and it idles perfectly.
but as soon as the IAC is plugged in the car will not idle below 2000rpm.
Any ideas people?
Old 22-09-2009, 01:28 PM   #10
REDAUXR6II
REDAUXR6II's Avatar
i have checked for vacuum leaks and cannot hear any evidence of this. i pulled the TPS off and found that it has gone very sloppy inside, so looks like that is the culprit.
I will let you know once i have replaced the TPS.
Old 23-09-2009, 11:21 AM   #11
REDAUXR6II
REDAUXR6II's Avatar
ok well the TPS seems to have resolved the problem, the car still idles a bit high but then pulls down to 800rpm.
i am resetting the ECU make the car relearn its settings
cheers
Old 23-09-2009, 01:57 PM   #12
REDAUXR6II
REDAUXR6II's Avatar
Well it appears that i spoke too soon.
The car is still idling at 2000 rpm.
I have done some testing and found the following:
When the car first starts idle is at 900rpm roughly
When you touch the accelerator it idles up to 2000rpm and will not move.
If you disconnect the IAC and start the car it idles at 900rpm, if you touch the accelerator it revs up then comes back down to about 1500rpm then settles down to 900 again.
I have replaced the IAC and TPS but the problem is still happening.
Any ideas on this? it is becomming very bloody annoying.
I have tried disconnecting the battery (positive) terminal for 1 hour to reset the computer but the problem still occurs.
Old 23-09-2009, 02:06 PM   #13
JMO
JMO's Avatar
Is the butterfly (circular bit inside) in the throttle body becoming stuck open perhaps?
Old 23-09-2009, 02:08 PM   #14
REDAUXR6II
REDAUXR6II's Avatar
Nah i checked that the butterfly is completely closed its almost like the IAC is sticking open, i have tried 2 different IAC units but the problem is the same.
Old 23-09-2009, 03:14 PM   #15
REDAUXR6II
REDAUXR6II's Avatar
i have done yet more testing and found a loud hissing noise (like rushing air) which i narrowed down to the gasket near the inlet to cylinder 1, I did the trick with the hose and my ear.
how hard is it to change the intake manifold gasket?
Old 23-09-2009, 04:22 PM   #16
REDAUXR6II
REDAUXR6II's Avatar
Ok i have found the hole in the gasket, its about 1cm long, a new gasket is on its way.
Is there anything i need to know about changing the gasket? such as the order to tighten up the bolts or if they require specific torque settings?
A question about this, since the air is rushing into the manifold would this cause the MAP to give incorrent air flow readings and tell the ECU that based on the air flow in the intake manifold that the throttle is open and to provide fuel based on this?
just curious thats all
Old 23-09-2009, 09:18 PM   #17
TE029
Blue Blooded
Hey mate,
As far as the torque setting goes for bolt tension there is one that comes in the packaging of a aftermarket gasket but not the factory genuine ones IIRC but that said providing you dont swing on them with 1/2 inch drive gear, use 3/8 drive and go as tight as possible.
From experience get a gasket (the metal one) for where the coolant housing mates up to the head at the front, they tend to leak once you remove and replace them. Cheap insurance and lets you access some of the bolts more easily if you remove it.
The job is not too hard but allow yourself plenty of time (took me about 2 -3 hours i think.) and plenty of patience.
The air that gets sucked in is unmetered air and leans the idle out and normally causes it to surge at idle rather than run smooth,
My idle speed was still fine so hope this fixes yours but that said if it is blown needs doing anyway hey.
Mick
TE029 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2009, 09:43 PM   #18
REDAUXR6II
REDAUXR6II's Avatar
Thanks for the info, ill grab that gasket as well, yeah hopefully it helps the situation, if its still idling at 2000 rpm after the change i will probably have to take it to someone.
Old 23-09-2009, 10:18 PM   #19
REDAUXR6II
REDAUXR6II's Avatar
i suppose you could describe it as a surging, when the car starts its idle sits around 900 to 1000 rpm, then if you accelerate past 2000rpm the car will slow down to 2000rpm then sit there until you turn it off and start again.
i noticed that if i put my finger over the hole the idle changes slightly so i am pretty sure that this should fix things.
Old 25-09-2009, 04:16 PM   #20
REDAUXR6II
REDAUXR6II's Avatar
Hey All,
Well new gasket is in a all problems are solved, since replacing the IAC, TPS and intake gasket i have resolved the following:
car not not starting on first try
car missing at idle
pinging
Old 25-09-2009, 08:34 PM   #21
TE029
Blue Blooded
Good work mate glad to hear the gasket fixed it,
Mick
Old 25-09-2009, 08:39 PM   #22
REDAUXR6II
REDAUXR6II's Avatar
Again Thanks all for the private messages and help
