Old 25-09-2009, 05:58 PM   #1
aufairmontghia
XR6
aufairmontghia's Avatar
Default AU fairmont Ghia Shocks??????
Hi All,
I need some good honest advice on what shocks to use on my AU Fairmont Ghia with IRS.
I can't afford to go Koni's or Pedders sports... They want too much!!!!
It's lowered & has pedders heavy duty springs 2638 up front & 2639 in the rear.
What do you suggest??????
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2009, 07:15 AM   #2
Pedders Bendigo
Suspension Expert
Pedders Bendigo's Avatar
Hi
Just be carefule it is not the strut tops that need replacing as the rear of those cars are common for it & makes the shocks seem like they are stuffed.
Also being lowered if the struts need doing you are much better off fitting either the Sports Ryder Struts or Koni in my opinion as the car is limited in suspension travel & will drive much better with the right strut. This also looks after the rest of the componetry by limiting the amount of suspension travel used allowing all other parts to last longer. Better value for monet over time. Hope this is of help.
Grant Phillips
Franchise Owner
13 Phillips Drive, Kangaroo Flat, Bendigo, Victoria, Australia, 3555
Tel: +613 5447 0009 Fax: +613 5447 2229
Email: bendigo@pedders.com.au
Multi Award Winning store Top Regional 03, 04, 06, 07.08,09,10 : Top Store 2005 & 2008 & 2010.
Pedders Bendigo is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2009, 08:47 AM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Originally Posted by aufairmontghia
Hi All,
As the Pedder man says get the right shock for the job, if you throw crap at it you will be back here in 6 months saying the same thing, save up for them if you have to as the right shocker will last 3 to 4 times longer than cheap and nasty in the end
Originally Posted by Riksta
Old 26-09-2009, 08:53 AM   #4
BIGJB
BIGJB's Avatar
I couldn't agree with the last 2 posts more.
I know as we all do that quality suspension is dear.
But in the long run you are so so much better off.
Do it once and do it right. Cheaper in the long run.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2009, 09:51 AM   #5
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Hi All,
I know where you are coming from!
Pedders down the road wanted a tad under 3 grand for their ryder suspension package i.e. shocks, springs, fitting and swaybars... and I'd be all for it... if it wasn't half as much as a paid for the car in the first place!
Been looking around and kings springs with Monroe GT shocks come in at around $600 for front and back, although im sure they are no where near the quality of pedders or konis :(
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2009, 10:31 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
The thing to remember when doing suspension stuff is...if you are doing it your self is when you ring around to get prices make sure you ask for the correct product, as Pedders have 3 basic shocks,Standard, Comfort gas , and Sports ryder, as do Monroe with std. gas ,GT ext. and other brands,the price difference between each is grade is rather significant , then if you decide to have then fitted you can compare the fitting cost from the various suppliers, this way you will able to compare all the cost involved
Old 26-09-2009, 10:31 AM   #7
ronwest
All Bran = Regular Member
It really depends on what type of driving you do and how you rate handling vs comfort.
I've had a few "non-expensive" (not Konis etc) combinations and for my driving - 90% long trips/10% city driving - the best compromise is the coil/shock setup I bought off GK.
I can't rem what they are, other than some sort of "touring" setup.
George!! What were those springs and shocks you sold me? lol.
When these need replacing I may look at Konis etc but I'd really need to be convinced that whatever extra I get in the handling/comfort stakes is worth the extra $$'s.
Old 26-09-2009, 05:37 PM   #8
azza11
azza11's Avatar
KYB, Boge is a good compromise. But you do get what you pay for.
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now.
*****XR PARTS WANTED*******
azza11 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2009, 10:53 AM   #9
aufairmontghia
XR6
Guys
Prior to this I had tickford springs up front & pedders touring springs 6409 in the back with monroe gt gas shocks all round.... I've also got the weight of the LPG gas tank to lug around!!!!
It drove like a bag of SSSHHH........t!!!!!
Now with the Pedders Heavy duty lowered springs all round & the same monroes, it's driving a heap better but want to improve it that bit more with new shocks???
I've heard KYB's are a good shock & great value for many money????
I want something a little better than standard though....
But I'm not sure what else to go for!!!!
Old 27-09-2009, 01:37 PM   #10
blueoval
Critical Thinker
blueoval's Avatar
I'll put a vote in for BOGE. They are a good compromise as AZZA has mentioned. Not overly expensive. They are german made iirc, and some merc, audi's run these shocks. (correct me if Im wrong). You can get the fronts in a short shock for extra travel ability on lowered springs too.
Check out our site sponsor Fulcrum suspensions for a deal. Be sure to tell em your a member for FFAU for further savings.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2009, 07:59 AM   #11
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Could always investigate Koni Reds if the yellows are out of your price range.....personally I'll put a vote in for Koni Yellows!!!
But BOGE would also be a good option. If they're still too much, try KYB???
Old 29-09-2009, 07:16 PM   #12
adumb
FG G6ET
adumb's Avatar
Hi i have KYB's in my Ghia, got them for around $480 and they ride very nicely. I was going to go for Boge but I'm told they dont make short shocks for the rear with IRS
adumb is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 10:44 PM   #13
Pedders Bendigo
Suspension Expert
Hi aufairmontghia
The Boges are not a bad shock & are available from you local Pedders store if you wish to go that way.
Grant Phillips
Franchise Owner
Old 29-09-2009, 11:57 PM   #14
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by Pedders Bendigo
Hi aufairmontghia
Thats good to know. Is this a branch only deal or australia wide?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 30-09-2009, 06:46 AM   #15
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
The ride quality of Koni yellows is fantastic. I would save up for them. You will not regret it. Depends how long you intend keeping your car of course.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2009, 11:03 PM   #16
aufairmontghia
XR6
Ok Guys
Any idea on the best prices for say boge, kyb's etc.... for da Ghia????
Old 01-10-2009, 07:05 AM   #17
Pedders Bendigo
Suspension Expert
Hi blueoval
This is Australia wide for all stores see how you go if you get no help let me know.
Grant Phillips
Franchise Owner
Old 01-10-2009, 07:06 AM   #18
Pedders Bendigo
Suspension Expert
Ok Guys
Hi aufairmontghia
Give your Pedders store a ring for the price on the Boges. If you get no help as above let me know.
Grant Phillips
Franchise Owner
Old 01-10-2009, 09:43 AM   #19
blueoval
Critical Thinker
blueoval's Avatar
Hi blueoval
Thanks mate, I already have BOGE shocks, but never knew Pedders do them also. Thats good as I have a Pedders around the corner from me that I could go to when my current shocks give out.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
