Old 11-10-2009, 04:54 PM   #1
KR1STO
Just another mock-up..
KR1STO's Avatar
Default My Fairlane running like crap!!!!
Ok guys, i need a hand...
Yesterday, the car started running like crap, and backfired on gas..
Ok, my first thought were plugs and possibly coil pack..
so i did the cheapest..plugs..
put new plugs in today, checked the gap.. all 0.8mm
started it up and reset the ECU..
now, it still ran rough..
i took it for a drive and it wasn't idling right when i stopped..
both on gas and petrol..
anyway, as i came off the accelerator and back on it around a corner, there was a huge backfire on gas and then it stalled..
when i started it back up on petrol it was idling at 3000rpm...
sounds like its only running on 4 cylinders and wont idle on gas anymore..
my thoughts now... headgasket..
i took the radiator cap off and ran the car..
water was flying out at idle almost as if there was pressurised air running through it constantly..
Could the headgasket be split and pressurising the cooling system..?
Is this a headgasket prooblem guys or have i done a little bit more damage than that..?
the car is running really rough and idles at 2500-3000rpm..
i've checked for vacuum leaks but there doesn't seem to be any..
any help appreciated..
cheers
kris
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 05:23 PM   #2
frd906
dont sound good mate, hope you fix it
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 05:26 PM   #3
CFOUR
The Destroyer
CFOUR's Avatar
You change you're air filter since the dust?
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 05:27 PM   #4
KR1STO
KR1STO's Avatar
i live in melb, so we didn'rt get the dust.. and yeah i washed the Air Filter (k&n) about 2000kms ago whe i serviced it..
cheers
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 05:41 PM   #5
craggy
Could possibly be a head gasket, my EF blew its gasket recently and it ran very poorly at idle and when starting. I found with my EF the water in the radiator stunk like exhaust when it blew its gasket so that might be a thing to check. If you have a compression gauge handy do a test of the compression on the cylinders. If one of the cylinders is down on pressure by more than 10psi then there is most likely something up with the head. Thats all I can think of at the moment, hope it helps.
SZ Territory 2WD Petrol
craggy is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 05:45 PM   #6
KR1STO
KR1STO's Avatar
cheers mate.. yeah it does help..
i'm going to test it tomorrow..
it does have an unusual smell to it..
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 06:00 PM   #7
craggy
If it is leaking and you have access to the appropriate tools, its quite cheap to fix it yourself (as opposed to taking it to a mechanic). My Dad and I fixed ours in about a week. We took the head off and found the source of the leak to be water leaking from the water gallery into the number 4 cylinder.
We took the head to a Cylinder head re-conditioners and got it fully reconditioned for $350 (Machined all surfaces, new valve guides, seals and pressure test). Add that to a Gasket kit and bolts ($170) and It cost us around $520 to fix.
Also as for any other internal damage to the engine, ours was fine after the new head and the guy at the machine shop said that the I6 engines are pretty tough on the bottom end and rarely get damaged from a leaking head. So hopefully its all good.
Old 11-10-2009, 06:06 PM   #8
KR1STO
KR1STO's Avatar
fair enough.. na i won't be doing that mate... i'll be doind an engine conversion.. been in touch with a guy with a lot of t-series things.. so a V8 will be going in if this is stuffed
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 06:08 PM   #9
The Monty
Just slidin'
The Monty's Avatar
It wont be a headgasket, if it is, it would be the first AU Ive ever heard of (cabs included) that has blown a headgasket.
It will be something else, give it a service with new oil etc, clean your throttlebody, replace oxy sensor, make sure your plugs are good, even try and run it around the block without the airfilter just to see if it is that. Do everything you can for free first, then see what you come up with.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 11-10-2009, 06:11 PM   #10
KR1STO
KR1STO's Avatar
i just did all that....
new plugs
new oil
new filter
cleaned air filter
cleaned throttle body
ran it without filter an ran with..
idles like its running on 4 cyliders and idles at 3000rpm..
i've checked all the vacuum lines for leaks..
what would be causing the water to be pressurising so much??
cheers mate
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 06:44 PM   #11
StealthAu
Don't stress about the flow of water if there aren't any bubbles apearing.
remover your intake, make sure the butterfly is closed, if so recheck all vacumm hoses. Check intake manifold bolts are done up tight.
Old 11-10-2009, 06:59 PM   #12
The Monty
Just slidin'
The Monty's Avatar
Your cat hasnt decide to collapse at all?
Old 11-10-2009, 07:19 PM   #13
KR1STO
KR1STO's Avatar
ok guys... well i went over it one last time... and i found a huge piece of the inlet gasket missing... the backfire must have blown it out...
it still backfired for a reason though so i'm going to change the coil pack to make sure..
now, to start taking off the manfold..
thanks for all the help guys.. it's much appreciated..
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 07:25 PM   #14
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
don't forget to take pics!!!!
Old 11-10-2009, 07:26 PM   #15
KR1STO
KR1STO's Avatar
as reference or for the forums??
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 07:29 PM   #16
Dave_Obsession
both! :
Old 11-10-2009, 07:30 PM   #17
KR1STO
KR1STO's Avatar
haha.. i've done em before, so i shoud be alright.. but i will take some and put em up for people that have never seen it done..
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 08:52 PM   #18
The Monty
Just slidin'
The Monty's Avatar
Its times like these when those 10mm ratcheting spanners come in handy. Those rear bolts are a pain in the butt, but with the ratcheting spanner, makes t so much easier.
Old 11-10-2009, 08:56 PM   #19
KR1STO
KR1STO's Avatar
thanks for reminding me... they're a pain in the aaarsse...
i'll pick one up tomorrow...
cheers for that bud
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 09:00 PM   #20
blueoval
Critical Thinker
blueoval's Avatar
I hope its nothing serious kris.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 09:04 PM   #21
KR1STO
KR1STO's Avatar
yeah me too... i'm gonna change the coil pack and the destroyed manifold gasket and see where we go from there..
if its stuffed then it's coming out and a nice V8 will be going in...
hopefully, it's not stuffed though.. couldn't happen at a worse time..
got so much stuff on atm..
anyway, i'll kepp you all posted..
cheers guys
see my car here:
[SIGPIC][/SIGPIC]
Old 11-10-2009, 09:59 PM   #22
GK
Walking with God
GK's Avatar
cheers guys
Before changing the coil pack, see how it goes with just the changed inlet manifold gasket. Then if no dice, go the coil pack. Simple things first.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-10-2009, 09:44 AM   #23
Dave_Obsession
any update on what's happening mate???
Old 12-10-2009, 09:48 AM   #24
KR1STO
KR1STO's Avatar
Just went to ford and got the manifold gasket...
I'm gonna start doing that tonight... couldn't have happened at worse time..
i'm doing 14 hour days at work..
so it's gonna be a big few days..
As GK said to do, i'm going to change the gasket then see how it runs..
If it's still rough then i'll change the coil pack..
If so, i'm going to do leads as well..
At least i'll be starting fresh on the ignition side..
New plugs, leads and coil pack..
I'll post some pics of the hole it blew out when it backfired..
It's quite a big piece missing...
see my car here:
[SIGPIC][/SIGPIC]
Old 12-10-2009, 09:57 AM   #25
Dave_Obsession
good luck with it mate!!! Hopefully it all turns out ok!!! What leads you running?
Old 12-10-2009, 10:00 AM   #26
KR1STO
KR1STO's Avatar
just ford ones... motorcraft i think...
should i change to something else?
if so, what do you guys recommend..?
see my car here:
[SIGPIC][/SIGPIC]
Old 12-10-2009, 10:05 AM   #27
Dave_Obsession
I've got Eagle ones going on later this week.....others recommend Top Gun, or Bosch...
Old 12-10-2009, 10:08 AM   #28
KR1STO
KR1STO's Avatar
Cool... is it worth going bigger than 8.0mm?
see my car here:
[SIGPIC][/SIGPIC]
Old 12-10-2009, 10:12 AM   #29
Dave_Obsession
I wouldn't think so.....but here's a link to the 9.0mm Eagle Eliminator ones...
http://www.eagleproducts.com.au/prod...eliminator.php
But 8.0mm should be fine, better than OEM anyway!!!
Old 12-10-2009, 10:20 AM   #30
KR1STO
KR1STO's Avatar
i might have a look anyway.. can't hurt to go 9.0mm i guess..
see my car here:
[SIGPIC][/SIGPIC]
