Old 08-02-2010, 12:17 PM   #1
HLC
Audi S3
Default Front Bumper Sag
hey all,
my front bumper sags in the middle more than an elderly womans.... anyway, wondering how i can get it sitting up nice and straight again?? already looked at the brackets and they are nice and tight, and dont know if there is any adjustment there?
was gonna look at putting a self tapper at the top rear of it into the honeycomb but you'll be able to see that and i obviously dont want that so yeah
Old 08-02-2010, 12:30 PM   #2
The Monty
Just slidin'
The Monty's Avatar
I used about 5 thick cable ties to hold it up. You can see them, so if you care about how your car looks, I wouldnt do it my way, lol.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 08-02-2010, 12:30 PM   #3
BA_GTR
My ghetto fix was to use a long screw through the little "hole" behind the bumper (the hole is behind the number plate) and attach that with a bolt and washer on the metal behind the bumper reinforcement. Probably not the best way to do it, but it worked for me and I figure that I might as well use it seeing as it's there
I'll try and see if I can find some pictures of it.
BA_GTR is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 12:39 PM   #4
GK
Walking with God
GK's Avatar
There is a way to do this with cable ties so that you can't see them. Works a treat!
Without my wagon in front of me, I can't quite describe it with total confidence, but I'll give it a try.
You take off the grille. You drill small holes in both the rear lip of the bumper and the white, plastic rio behind it. You simply use the smaller cable ties to attach the bumper to the reo. As you do it gives the bumper a bit of a tummy tuck! LOL!
When you put the grille back on, if you've done it right, the grille will hide the cable ties.
It was JC that did mine, so I suspect he'll be along soon to tell you! LOL! At least he'll correct me if I missed some important details in the description.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-02-2010, 12:48 PM   #5
BA_GTR
I used a 3/16" x 75mm screw to do it, it's basically just the right length And your number plate covers that 'hole', you need to push through the plastic to get it though Have a look at it and you'll see what I mean.
Oh and ignore the dodgy paintjob attempt, it was worth the effort in learning things the hard way such as using MASKING tape instead of stickytape :, and sanding the primer even though the spray can says you don't need to! :
Old 08-02-2010, 02:44 PM   #6
GK
Walking with God
GK's Avatar
There's another way to do it! A lot quicker and simpler too I guess.
What does the fastener, screw into? The reo I guess?
GK
Now gone!
On LPG
Old 08-02-2010, 04:33 PM   #7
BA_GTR
There's a hole in the metal that the bumper reinforcement holds onto (in between the two middle pieces of reinforcement). That's what I was trying to explain in my first post :p
Old 08-02-2010, 06:57 PM   #8
GK
Walking with God
GK's Avatar
I thought the hole you were describing was the hole in the bumper. That's the only hole you actually mentioned.
In any case, so there's a hole to screw into after you insert the screw into the hole in the bumper, and push through the bumper plastic? Is that what you mean?
GK
Now gone!
On LPG
Old 08-02-2010, 08:17 PM   #9
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Originally Posted by HLC
hey all,
Henri with your new wheels whos going to look at the bumper?
UK
Or you could 'pop a cap in its ***' if it doesn't sit up (Give it a 9mm uplift)
Old 08-02-2010, 08:20 PM   #10
Mont5.0
Mont5.0's Avatar
i put 2 self tappers on the back edge(between the headlights) into the honeycomb on my old Mont bar. they were hidden by the grille.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 08:56 PM   #11
JC
JC's Avatar
Cable ties as described by GK FTW!
Ford Performance Club ACT
Old 08-02-2010, 09:14 PM   #12
GK
Walking with God
GK's Avatar
Question
So the description was okay then my old friend? LOL!
GK
Now gone!
On LPG
Old 08-02-2010, 09:37 PM   #13
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
I'd be careful screwing anything into the reo, department of transport up here in QLD are a little pedantic about such things...
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 09:37 PM   #14
JC
JC's Avatar
GK
That it was, young fella!
Old 09-02-2010, 08:39 AM   #15
GK
Walking with God
GK's Avatar
Wink
I'm as old as you mate! Well not quite! LOL! I will be 40 this year however! I was referring to the fact that we've been friends a while!
GK
Now gone!
On LPG
Old 09-02-2010, 10:07 AM   #16
JC
JC's Avatar
GK
Oh, LOL. Once you hit 40, you become more age sensitive!
Old 09-02-2010, 11:51 AM   #17
GK
Walking with God
GK's Avatar
Smile
LOL!
GK
Now gone!
On LPG
Old 09-02-2010, 12:23 PM   #18
Uncle_Ken
Uncle_Ken's Avatar
GK
You guys are friends with Grandpa Simpson, right?
UK
Old 09-02-2010, 04:42 PM   #19
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
UK
LOL
Old 09-02-2010, 05:32 PM   #20
grandpa_spec_F6
AFF Whore
I'll be officially old this year... im turning 20 :P
<Insert joke about sagging appendages here>
Favorite Quote:
Old 09-02-2010, 06:02 PM   #21
GK
Walking with God
GK's Avatar
Wink
You young-ens are having a bit of a gag at the expense of us more mature members! LOL!
GK
Now gone!
On LPG
Old 09-02-2010, 06:32 PM   #22
BA_GTR
GK
Exactly that! It's almost as if it was designed as an alternative method to tighten the bumper up because the plastic in that 'hole' was so soft, I was expecting to have to drill through it but just pushing the screw through worked fine
And I'm still 18, here I was thinking I was getting old :P
Old 09-02-2010, 10:29 PM   #23
DJM83
Barra Turbo > V8
DJM83's Avatar
Car-Bra : : : :
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2010, 01:04 AM   #24
HLC
Audi S3
Originally Posted by DJM83
Car-Bra : : : :
HAHAHAHAHAHAH!!!!!!!
HAHAHA
im even starting to feel old compared to you kids... and im only 22 lol... had my AU since i was 17 but! :
