as the title says au upper door frame , , i was a bit close to a fence post, i checked the door for clearance thinking i was clear of the post but did`nt notice a piece of metal up higher sticking out from the post and gave it a wack, on the higher series doors? with black frames it looks like there is a metal trim on the door frame, i`m wondering if this is a replaceable part.
i`ve managed to take some of the buckle out of it, but it looks crappy in the flesh and ever since i had the car the drivers door frame looks like it has 4 or 5 tiny dents in it , no one else would probably notice them but........ i know they are there ![]() |
heres one more pic........
The black plastic strip on the doors is removable,
But you have to be carefull not to break it, best bet would be to get a spare couple of sets just in case
thx mate but its actually the upright bit of the door frame , from behind you can see it( the black sheet metal bit folded over the frame), the first and second pic, my photography suks, it looks worse in real life.
All Bran = Regular Member
Must be the weather for it. Last night I scraped mine on the passengers fr guard, fr door and slightly on the rear door.
Apparently big trucks, traffic barriers and me are a bad combination :( There's no actual dents and most of it buffed out (true, lol) but a couple of nice scratches down the side. Oh well, maybe I two-tone it sooner rather than later. |
thats bad luck ronwest, its bugger when you try really hard to look after your limo but ---- happens anyway, i might get another door , the same door had champagne bottle roll of the centre median strip on a windy day my front wheel caught it, smashed it and sent shards flying into the lower paint work , did`nt dent it but scratched the crap out of it :(.
![]() Join Date: Dec 2006
They are removeable, just held on by a few strips of double sided tape.
Be careful removing or you may bend it worse, cut the tape while pulling is best, then you can panelbeat and repaint. I think you unscrew the top black door trim (the outside strip between the painted metal and the glass) there should be a small screw on the outyer door edge, pop it off and the metal part tucks in behind here as well. Hard to explain but go slow and you'll be right |
ahh you beuty , thanks mate.
