Old 09-06-2010, 05:13 PM   #1
Serge
Serge's Avatar
Smile Loud Clicking/Ticking Rear Left Wheel IRS
Hey fellas, did the routine search with no results. I have a loud ticking/clicking noise coming from the rear left wheel. I replaced disks, pads, handbrake shoes and every little screw and bracket in the handbrake mechanism (bought the PBR rebuild kit) But the infamous noise is still there.
Doesn't make a difference whether driving straight hard right or hard left. I had looked at the brake dust protector to see if it's bent and no go all seems A OK. In my experience wheel bearings are clunking or metal on metal noise. Car is AU II Ghia IRS. Any help or advice will be really appreciated at this point.
Serge is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 06:02 PM   #2
BuckTooth
Feel the boost
BuckTooth's Avatar
Hey Serge, Do NOT be fooled by the wheel bearings mate. I just had to replace 1 in my xr8. It sounded like a rock catching on my disk, but unfortunately the bearing had actually been chewwed up. So i know its extra hassle, but definately worth checking just to be on the safe side.
2005 BA Mk2 XR8 ...... Let the fun begin
Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
BuckTooth is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 11:21 PM   #3
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Had to replace my hub and axle as the bearing was flogged out. Check the HOW-TO section, there is a guide on there.
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2010, 11:14 PM   #4
mracoval
easy way to check if the bearing is shagged or perhaps just loose is to raise the wheel off the ground and see if there is any movement. I had an issue where the hub nut on the brake end of the drive shaft kept coming loose. the only thing holding the wheel on was the brake disk that couldn't get past the caliper assembly. I ended up tack welding the nut as a temp solution and then changed the whole rear end ala ebay. was cheaper than sourcing hubs.
mracoval is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2010, 07:34 AM   #5
aufairmontghia
XR6
aufairmontghia's Avatar
My left bearing in my ghia was shagged... Similiar noise.
When I jacked the car up & placed on stands, I ran the car & I noticed the wheel rocking from side to side!!!!
Upon pull down I found The bearing was shot... It had seized up & then let go!!! Which ended up wrecking the hub as well...
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
