Old 04-07-2010, 11:21 AM   #1
TheInterceptor
Cruising...
TheInterceptor's Avatar
Default Engine braking
Heya, got a question for you guys.
How do the BTR's handle manual downshifting and using it to slow the car down?
Ive read that throwing it in first isnt such a good idea but on the long term, how do these boxes handle shifting from D to 3 - 2 - 1?
My old box didnt really do it... the new one though is fantastic at it.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 11:38 AM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
There must be a reason for you wanting to do this with an Auto. I'm guessing it's so you can impress bystanders with the exhaust note ?
Old 04-07-2010, 11:53 AM   #3
TheInterceptor
Cruising...
haha no particular reason, only time id use it for is when the car is carrying some real heavy weight down hills, my driveline is stock apart from a K&N filter so no awesome sounding exhaust. :P
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
Old 04-07-2010, 12:03 PM   #4
DJM83
Barra Turbo > V8
DJM83's Avatar
Different auto but, in my TE i use ESS 90% of the time but i never down to 1st i always let it do it by itself.
With an I6?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 12:18 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
Ah, in that case take out of 'D' for drag and use 'R' for race
Originally Posted by DJM83
With an I6?
Oops!
Old 04-07-2010, 12:26 PM   #6
DJM83
Barra Turbo > V8
DJM83's Avatar
Old 04-07-2010, 01:05 PM   #7
Stattic
Stattic's Avatar
I don't trust downshift to first if i'm taking corners Iike to sit in 2nd, it just smacks down too hard when you downshift to first, if you're in 2nd just accelerate so it kicks down and then hold it in 1st and change when you want
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 01:05 PM   #8
broken_suave
broken_suave's Avatar
I use slight engine braking (ie: D to 3, occasionally 3 to 2) to maintain smoothness and pricise control over speed. I do also occasionally manually shift the auto during a bit of spirited driving, but I use a bit of mechanical sympathy at the same time. I dont drop it to too low of a gear before the speed allows for it. I know at what revs I can shift down without overstressing the box. However I cant imagine that it would be great for box life if you did this a lot.
So you can do it, but I wouldnt do it all the time.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 01:34 PM   #9
JC
JC's Avatar
I use manual gears in mine all the time. If you throw it to first, it will not actually engage first, it will only go into first at low enough speeds.
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 01:35 PM   #10
The Monty
Just slidin'
The Monty's Avatar
Well, Ive had my 2 AU's for 5 years, and about 200000km's and use the gearbox manual 100% of the time. I havent had one gearbox/uni/diff go from this, only from the drags, but no gearboxes there either.
If you change into first, just lift your foot off the brake, and it doesnt slam in, and reapply the brake when it has engaged. You can get used to it so its pretty much seamless. In saying that, putting it back into first in the wet will cause a bit of a compression lock up, so hold on!
Just do it.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 04-07-2010, 01:36 PM   #11
The Monty
Just slidin'
The Monty's Avatar
Around 60-65 it will go in.
Old 04-07-2010, 03:09 PM   #12
broken_suave
This is what I've found, but around 50-55 is more comfortable..
Also on the exhaust rumble thing, my old catback had an awesome deceleration crackle/burble. Since getting my extractors/cat/mandrel 2.5" I thought at first that it didnt burble on decel, but I've realised it does, its just much deeper and softer. Its harder to hear, but sounds a whole heap meatier.
So when going down a slope I do occasionally open the window, drop down a gear, and listen to the deep thumping burble. Its nice, gotta get a bit of enjoyment out of the car ;)
Previously:
Old 04-07-2010, 03:19 PM   #13
DJM83
Barra Turbo > V8
DJM83's Avatar
Standard auto maybe but my T2 will do it at about 60kph (did it by accident one day)
Old 04-07-2010, 06:04 PM   #14
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
definately for towing i did it, and to hear my 1000 dollar exhaust on quiet nights.
now i drive my cars, rather than steer them :P
manual all the way baby
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 06:14 PM   #15
frd906
Every now and then id manual down shift, when im towing a tralier empty or full i will always use manual,
i found with my new gear box when shifting from d to 3, then 3 to 2 with my foot on the brake or letting it glide with out my foot on the gas, when i downshift it, i cant feel it go into the gears till i my foot touches the gas agian,
in my old gear box, i could feel it, specially from 3rd to 2nd could defintly feel the car pull back, didnt really like it, box served me good though, the hard years under my foot lmao
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 06:57 PM   #16
Stattic
Stattic's Avatar
The cars supposed to pull back when you downshift if you don't have the throttle open
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 04-07-2010, 07:13 PM   #17
HLC
Audi S3
well i almost always drove "manually" with my auto, including engine braking, into first and everything. the exhaust note gave me a chubby. i could also blip the throttle for extra **** factor and it sounded sweet~
the box took it fine, however i did have it serviced, all fine, but then it developed a small leak, which meant more and more oil dripped out, and on a hot summers day after a thrashing, i cooked it and it dumped oil all over my drive way.
and as a result, the C4 clutch band is now gone, and i have no engine braking.
lesson to be learned, abuse it and think "she'll be right, its just a small drip", youll stuff it. if i had of looked after that little leak when it developed,im sure id still be listening to my car popping and crackling and sounding real angry all the time.
Old 04-07-2010, 07:44 PM   #18
frd906
its a bit wierd, downshifting on a hill manually is fine no problemo, but rolling down a hill do 60 ks an hour with no gas on, shifting back from d to 3 then 3 to 2nd i cant feel it shift, but if i have gas on doing 60 and manualy shift back i can feel it.
Old 04-07-2010, 07:50 PM   #19
frd906
when im rolling down a hill ill put it into second doing 60 , then ill touch the gas and its in second already dosent need to kick back, its in the gear already, its a bit wierd to my old box, maybe im not just use to it
Old 04-07-2010, 08:12 PM   #20
BuckTooth
Feel the boost
BuckTooth's Avatar
I gotta put my hand up, lol. Nothing does sound as good as a V8 rolling down a hill with engine braking I do use the engine braking idea occasionally, but i more so leave it to when i'm towing something.
2005 BA Mk2 XR8 ...... Let the fun begin
Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
BuckTooth is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 08:16 PM   #21
TheInterceptor
Cruising...
Thanks for the replies fellas
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
Old 04-07-2010, 08:33 PM   #22
mik
mik's Avatar
i use the manual gears a bit myself, rarely drop into first unless crawling, but on the western ring road tonight it was bumper to bumper for some reason, 20/40 kph :( , i find it good to go a little slower than the cars in front speeeding up slowing down speeding up slowing down and hold 2nd at a steady pace, never had a problem with the auto.
Old 04-07-2010, 09:38 PM   #23
robbyj
Rob
robbyj's Avatar
when i first got my cat back less rear muffler i must admit i did it a couple of times... 60 back into first to hear the crackle and pop.
But i guessed it couldn't be good for it.. so i stopped. Occasionally if traffic is crawling along ill chuck her back in first.. but i wouldnt think it would be healthy doing it all the time from speeds back into first.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 09:42 PM   #24
GS608
Very rarely do i go down into 1st, bloody things gives me that lovely gearbox whine, still get plenty of crackle and pop in 2nd
Old 04-07-2010, 09:50 PM   #25
AUIIPURSUIT
pursuit ute baby
get a manual up ya !!!
Old 04-07-2010, 10:22 PM   #26
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
The gear gates (3-2-1) are designed for exactly what u are using them for. Just don't abuse them. The more the gearbox shifts the shorter it's life. Reguarding low (1st) when selecting low the gearbox applies the rear band, that's why harsh engagement, the rear band is only used for reverse usually. When in drive wilst in first at lights, the rear band is not on, but the one way clutch, the rear band is only on in low. Same goes for selecting neutral at lights. Great way to put unessasary pressure and wear on the front clutch when engaging drive again. So leave in drive at all times and let the converter do it's work. Also don't stall the car up, overheats the oil in the converter and substancially reduces the oil life, therfore also the transmission life. Some useless facts for a sunday night. Later.................
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!!
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 11:19 PM   #27
AUIIPURSUIT
pursuit ute baby
thanks auturbo6... even though i could never drive another auto again, i love learning every day.
Old 05-07-2010, 01:52 AM   #28
Stattic
Stattic's Avatar
so auturbo6 its bad to sit in neutral at traffic lights?
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 05-07-2010, 07:45 AM   #29
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yes, auturbo6 is correct. Putting it in neutral at the lights is unnecessary and probably a bad thing, they are designed to be able to cope with sitting all day long in drive with the brakes on.
Old 05-07-2010, 09:25 AM   #30
RG
Back to Le Frenchy
RG's Avatar
Every time I go anywhere that I can get the sound reverberating I will do it.
It's a V8, how could I not?
