Gday guys and girls.
First post; just wondering what you guys thought was a resonable price for a ford falcon au II actuator to be fixed. Issue is my central locking will not open the car. Drivers side locking makes whirring sounds like its trying to pop up, but fails to. Key will not open either. Thoughts? Thanks in advance |
Flairs - Truckers Delight
Hi Saha,
These threads below, all active in the last fortnight, should give you a good idea. http://www.fordforums.com.au/showthr...light=actuator http://www.fordforums.com.au/showthr...light=actuator http://www.fordforums.com.au/showthr...light=actuator http://www.fordforums.com.au/showthr...light=actuator A quote from an auto-elec or mechanic is always a good idea too. Cheers Mr Hardware ps i came up with all these threads by doing a search.
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
And some how to as well
http://www.fordforums.com.au/vbporta...article&id=747 and http://www.fordforums.com.au/vbporta...article&id=756 UK
$50 at most wreckers.
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
