Rob
I know there is probably a heap of threads about shift kits but i want someone to explain exactly what I'm asking as i don't fully understand them
Im thinking of getting one for my Series 1, To firm up the shifts .. I'm guessing this helps it go through the gears better and 'firmer' making performance slightly better? makes the car slightly quicker? So I'm going to need a tranny cooler or so iv read.. ? When driving with the shift kit on.. do you 'HAVE' drive using the gears aka 1st.. 2nd.. 3rd.. D Or just simply drive with it in D. Cost wise what am i looking at for the kit and a tranny cooler? and can anyone recommend a kit/cooler? Thanks in advanced =D
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
Lost Boost Gained Class
mate i have all that for sale that u neeed ill pm u about it later
2006 BF Fairmont Ghia
2001 AU Falcon |
Rob
Ok cheers bud.
#4 | |||
Diagram: Last edited by Jack91; 08-07-2010 at 11:52 AM. Reason: Added shift kit link |
Rob
Thanks heaps mate.
To be honest, theyre pretty useless. Damage can and has happened before (engine mounts, uni joints because of the smash of the gear change). Also been well documented that they dont help at all on 1/4 times. But I guess for less than $50 might as well give it a try.
Rob
Yea i'm not really sure about it now. Would be nice to have the more sportier feel.. driving an auto somehow lacks that.. haha
But don't wanna wreck the car.
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
I just bought the Adjustable Shift Kit from www.shiftkits.com.au - total cost $130 delivered from WA to Melbs. - I couldn't be stuffed making one
The reason why i bought it is I when the Auto changes gears down the 1/4 mile at WOT the RPMS flare up about 500 before the change - the Flare is so the change is smooth in the std tranny It's like if you have a manual and you change gears, when you are changing gears the RPM flares up as the clutch goes in, then when you select the next gear you ride the clutch somewhat so the change is smooth - this is not at WOT and you take your foot of the gas between changes From what I have read the with the ShiftKit it will be like dumping the clutch when changing gears with WOT/full throttle. The 1/4 mile time in my Sig is the Fastest my car has gone I am going with same setup with the only change the Shift Kit and see what results i get
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
i have one of them sift kits form shiftkits.com.au and it works well my white car had the same mods and soulink and he has a S2 and my s1 stuck with him as soon as i put the shift kit in mine leped infront of him thay make that 0.00001th of the dif
The only thing i dident like was when it was set to hard shift it feelt like the tail sharft was Comeing thought the floor but it dident do any damage to the car at all
2001 AU Falcon |
oh and when your raceing and u got a heap of work done it helps look after the tranny because theres less of a risk of slipping because the changeing isent slow
2001 AU Falcon |
#11 | |||
Rob
mm still undecided. Id only have it on if i was giving it a bash or some ****a in his VN pulls up beside me at the lights (happens a lot in my town lol)
The shift kit had nothing to do with your S1 when the diff broke poelwyk? If your selling your shift kit PM me the price. Quote:
#12 | ||
Rob
There are mixed feelings and opinions on them from what iv read. So long as its not damaging i think ill go for it..
Is there any evidence that it is/is not damaging?
#13 | |||
Blueoval has all your answers
#14 | ||
Rob
Ok thanks mate. Looks like you have been doing some research too =p
#15 | ||
Documented damage? Well I know for fact that BenJ (member on here) snapped an engine mount from using one, uni joints and diff are vulnerable but I cant clearly remember any specific cases. Trans cooler isn't required when fitting a shift kit. Not even in the slightest. Shift kits will actually REDUCE the amount of heat in the 'box. However an external trans cooler is always a good idea but I say again its NOT COMPULSORY just because you are fitting a shift kit.
Honestly though, the amount of people who say there are no gains in real life vs those who say there are gains, must be 10 to 1. If it really was that easy to knock off a few tenths dont you think everyone would be doing it? All this is good for is showing off by chirping 2nd and 3rd. Thats it. Should add too that Ive had one on an eb I6 fairmont and a ef I6 gli, and my AU XR6 had a sort of "built in" version (ford called it adaptive shift, and it kicked in when you least expected it) |
#16 | ||
Rob
Righto, plus the factor its more... 'exciting' to drive.
So having the kit wont produce more heat for the trans correct? Edit: When driving with it on
#17 | ||
Correct you will actually be getting less heat.
Its not more exciting mate, its just silly. Trust me. Theyre total crap. But if you must try it, build your own and save yourself some money. |
#18 | ||
Rob
Righto, do you have a link to a how to? .. i found an example for an EL.. dunno if its same thing for an AU
#19 | ||
Sorry I take that back they are good for powerful cars as the other guy said so the gearbox just doesnt slip. So there, it has 2 uses. Showing off and helping to preserve high power cars.
#20 | |||
#21 | ||
Rob
Ah sorry didn't see the link. Thanks for all your help mate.
#22 | ||
Deleted
#23 | ||
Rob
na iv got it, looking at it now. all good
#24 | ||
Oh yeah you'll also need a drill and a sharp drill bit to drill out the rivet holding an earth wire to the car body from the ECU. As you need to take the ECU out once you put it back in just get a self tapper or another rivet to put the earth back on the car. I think the car wont start without it on.
#25 | ||
Rob
Ok thanks mate.
#26 | |||||
My engine mounts are new so i will be very surprised if they break - and yeah if you have a part on your car thats about to give up the ghost - uni joints and diff and you use a shift kit then yeah they "may" break BUT then again they may just break from normal use Quote:
![]() Quote:
I have only heard about how the tyres chirp when changing gears and about how hard it shifts If it works on my Auto and i dont get the flaring when changing gears then it will work down the 1/4 - if i get .1 or .2 better then its an improvement
#27 | ||
Back on the road
Had a bad experience Davo XR? Frankly I wouldn't drive my XR8 hard without one, for the reasons mentioned by sorted.
I've done about 60-70 1/4 mile passes, and 80,000kms since fitting my fully adjustable shift kit. No broken bits at all. I wouldn't recommend anything but the fully adjustable kit though. If it feels like it is thumping on gear changes then turn it down a bit....chirping tyres does not make you faster!! If your driving your car hard, you need a decent trans cooler anyway, shitfkit or not. And change your tranny fluid every 50,000km.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#28 | |||
#29 | |||
Back on the road
I still beleive firming up the shifts is absolutley necessary for the longevity of your auto gearbox if you are going to indulge in any "performance" driving. It doesn't really matter if you acheive that via a shift kit or a Flash/J3 Chip tune.
#30 | ||
Former BTIKD
'Shift kit' sounds very much like the 'Power/Economy' button on my barge!
