ROCKING THE EL FUTURA
hey guys another delemer yet again im thinking i should change my cat as the old one is gone and im getting noises from it and fuel econ has gone down the drain i was looking at these...
http://cgi.ebay.com/Kenobi-100-CPSI-...item2c53f2436d any advise befor i press the buy now button....
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
Lost Boost Gained Class
looks ok to me
I had a Balistic one on my white au good bit of kit
2006 BF Fairmont Ghia
2001 AU Falcon |
Resident AFF detailer
Ballistic Cat FTW.
Go check out the Sureflo Exhaust section of our forums - they're a site sponsor... You've missed their recent sale on these, but their regular price plus postage is about the same cost as what your eBay cat would be including postage. I have a Ballistic and it really is a quality item - had a good look at it when it was delivered and it's very well put together.
#4 | |||
would i need a bigger outlet or the 2.5inch is ok?
2.5 in .25 out 4" body thats what you need mate
2001 AU Falcon |
well i just pressed the buy now button as the ballistic ones were a little dearer..
Flairs - Truckers Delight
OBI WAN
Powered by Ford
I just had 2 Ballistics put on with pacemakers, very happy ....
#9 | |||
![]() Join Date: Jan 2005
Anyway, $250 delivered is a not unreasonable price.
rexnet
i have a 3" kanobi on my XR6 and it seems to do fine.
thans for the feedback every one.
#12 | ||
The only thing u'll see!!
The cat does not affect fuel economy, it mearly acts as a catalyst to the exhaust gases that leave the engine making them less harmfull for all.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!! |
If the cat is blocked it will
#14 | |||
When a cat blocks up it is due to issues up stream, I.E. engine. Most cases of cats melting I.E. BLOCKING UP are caused by either running exessively lean or running rich and burning too much fuel in the exhaust. Having said that one of the cat's main functions is to run hot enough to burn all unburnt fuel before it can escape into the atmosphere. (How about the next person that wants to argue with me go watch some FULLY SICK drifting or some FULLY SICK drag racing or burnouts man, man, man.........................) Later..........
#15 | |||
Lmao, we are all aloud to post our opinions and suggestions to either diagnose the problem or think of a solution to fix it, At least we run a cat on our cars ![]()
#16 | |||
#17 | ||
Causes of Catalytic Converter Failure
There are two ways a converter can fail: •It can become clogged. •It can become poisoned. There really is no "inspection port" for the consumer or mechanic to see an actual clog in a converter. Often, the only way to tell if a catalytic converter is malfunctioning (plugged) is to remove it and check the change in engine performance. When a clogged converter is suspected, some mechanics temporarily remove the O2 sensor from the exhaust pipe ahead of the catalytic converter and look for a change in performance. A catalytic converter relies on receiving the proper mix of exhaust gases at the proper temperature. Any additives or malfunctions that cause the mixture or the temperature of the exhaust gases to change reduce the effectiveness and life of the catalytic converter. Leaded gasoline and the over-use of certain fuel additives can shorten the life of a catalytic converter. A catalytic converter can also fail because of: •Bad exhaust valves on the engine •Fouled plugs causing unburned fuel to overheat the converter *Sometimes you can tell that a converter is clogged because you don't go any faster when you push the gas pedal. Also, there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A partially clogged converter often acts like an engine governor, limiting the actual RPMs to a fast idle. A totally clogged converter causes the engine to quit after a few minutes because of all the increased exhaust back pressure. The catalytic converter, like the rest of the emissions system, typically has a warranty length that exceeds the term of the warranty for the rest of a typical U.S. automobile.
#18 | ||||
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors Last edited by Auslandau; 10-07-2010 at 09:16 PM. Reason: Not required .. |
#19 | |||
#20 | ||
Enough said.
#21 | |||
#22 | ||||
Chasing a FORD project!
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
#23 | ||
Missinterpretation is rip on this forum! Which only enforces my contempt for all!
#24 | |||
#25 | ||
335 - STILL THE BOSS ...
I would say the question has been answered and the rest is getting just a little bit silly ....
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
