Old 03-08-2010, 05:19 PM   #1
BLSTIC
Default Just bought a skid car...
So I'm back in an EF. The poorest example of which I have ever driven... But for $100 i got an EF Gli with 410,000km (!!!). But with that many km it must have had at least one gearbox rebuild, which explains the sweetness that is the shifting... It also has a decent amount of poke, so it might have had a fresh engine at some stage.
Completely stock, damaged front passenger door (won't open, side impact).
So yeah, next step weld diff and disconnect rear brakes. I might also make an electronic shift kit.
It *might* also get a second radiator and oversized transmission cooler mounted in the boot, just to be sure that I don't kill it... Either that or hook up a water spray to the current one, which appears to work fine...
Chuck Norris beat Tetris
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 05:21 PM   #2
Grippy
Racing improves the breed
Grippy's Avatar
You cant go wrong for $100 bucks. Make sure you post up some skid pics
1970 Mini Cooper S Historic Group Nc Touring car
1964 Mini Cooper S Historic Group Nb Touring car
2024 Subaru Outback Touring XT
Victorian Hill Climb Championship
Grippy is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 05:24 PM   #3
BLSTIC
Yeah well the worst that can happen is that the car can burn to the ground. In which case I'll win the carnage trophy and $100 would have been so worth it for that.
Old 03-08-2010, 06:57 PM   #4
BADEF-6
Moates Ostrich 2.0 User
BADEF-6's Avatar
lol good stuff! one of the guys at work won the carnage award at the cairns burnouts. he cracked the block open then got his mates car and blew the guts out of the diff...
It great fun when its cheap and if you get a wrecker to get there name on it, your on easy street.
Daily: Golf 6 GTD. Black Magic, ABT goodies. 153.2fwkw 480nm @1500rpm
New Project: 1973 GTR Torana 2door. Track/Targa/Hill Climber. Soon to have a 4.0L OHC and a Turbo.
EF Fairmont: Twin Charged 6 -481rwkw 1038nm @3500rpm (Fully Engineered) (SOLD)
IM BACK
BADEF-6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 07:06 PM   #5
iliov
iliov's Avatar
post some photos of it man
iliov is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 07:10 PM   #6
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Here are some links from AFF of Burnout Cars - give ya some ideas - ORSM
http://www.fordforums.com.au/showthread.php?t=11279845
http://www.fordforums.com.au/showthread.php?t=11300178
http://www.fordforums.com.au/showthread.php?t=11289434
http://www.fordforums.com.au/showthread.php?t=11286271
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 09:54 PM   #7
BLSTIC
Burnout Car Album (imageshack)
Old 04-08-2010, 01:06 PM   #8
Sorted
Sorted's Avatar
Originally Posted by BLSTIC
looks like my car in bogan spec lol
Tuned by DYNOMOTIVE
Old 04-08-2010, 07:34 PM   #9
BLSTIC
A little development on that front... I might stay in aus a few more weeks. It might get registered depending on how good (or otherwise) the suspension is. Apart from that door the body is straight, straight enough for gloss black...
Either way it's doing skids. If it comes to being registered, I'll keep the diff I'm about to lock for the burnouts ***edit: and another to actually drive with***. The lack of ABS makes it a lot easier to disconnect the rear brakes every time I feel the need...
Old 08-08-2010, 11:46 AM   #10
BLSTIC
Upon closer inspection the car already had a small trans cooler... I was pressed for time so I didn't end up hooking up the air-con core as the trans cooler, just left whatever was on it.
So I took it to the burnout comp last night and did pretty well (didn't get into the finals, but the 6cyl class was the biggest, and it was my first proper burnout).
We (me and my mate, the second driver) did 4 skids each. Destroyed 4 sets of tyres between us... It sat at the top of 2nd all the time in a standstill with 15's on it (3rd with 14's, may have got 4th if it wasn't for the speed limiter). With the 15's you could do what you liked in 1st (circles etc), 14's it would struggle just a little to do the same in 2nd.
Hopefully the professional photographer got a few pics of it... my camera died.
So now what should I do with it? Revs check then RWC inspection?
Turns out the motor has been reconditioned at some point too.
