Old 05-08-2010, 07:41 PM   #1
xp_wannabe
xp_wannabe's Avatar
Default My firewall is leaking but not through the clutch cable...
Hey guys my 5 speed AU2 XR6 is leaking water from the firewall and onto the brake pedal...
Has anyone else had this problem and can you give me some tips on how to fix it?
Its coming from above a bracket that is spot welded to the right of the pedal box, the bracket holds some wiring with an orange plug, see the pics...
you can see the water dripping off the loom in this pic below:
Also what is up with my pedals, are everyone elses bent like mine? the pedal box seems very flimsy...
the clutch pedal is alot higher than my brake pedal too, should I try and adjust this out?
xp_wannabe is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 07:45 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
perhaps that avatar's not the best idea when asking for help
and lots of people have water in the footwell issues - in fact i think it's covered in the common AU faults sticky thread - otherwise there'd be threads and threads on this. a search might do you some good.
Old 05-08-2010, 07:53 PM   #3
sleeper393
sleeper393's Avatar
i'd be looking at where the rust is in the third pic, as that is above the black wire harness, looks to dripping from there to the wires below
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 07:55 PM   #4
xp_wannabe
xp_wannabe's Avatar
haha sorry mate it was not meant to be taken so literally but I have fixed it now - I call it "sunshine and happiness"
that thread is 18 pages long, and I have done a search, seems most people's leak is from where the clutch cable enters the firewall, and there is a well documented fix for it (weld the crack and then reinforce)
mine is not coming from there though, mine is coming from the far right hand side of the firewall, it seems under the brake booster
Old 05-08-2010, 07:56 PM   #5
sleeper393
sleeper393's Avatar
nice calming avatar , lol , im thinking windscreen leak , then dripping onto that steel bracket , then onto the cables
Old 05-08-2010, 08:00 PM   #6
Mr Hardware
LOL WUT
also
sikaflex everything
Old 05-08-2010, 08:00 PM   #7
xp_wannabe
xp_wannabe's Avatar
thanks mate. I have had the windscreen checked and its not that. In the third last pic you can kind of make out a hole in the shadow above the loom with the water on it, that is where its coming from
Old 05-08-2010, 08:08 PM   #8
kenz
BOSS Pilot
kenz's Avatar
pretty sure this is a fairly common problem in manual au's. I remember when I had mine I tryed on here to find out what it was and lots of people had the same problem with no solution
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 09:26 PM   #9
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
This will fix it.
http://www.fordforums.com.au/showpos...37&postcount=1
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 09:30 PM   #10
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Originally Posted by CRAIGAU3220
+1, very common problem with the spot welds cracking
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 09:36 PM   #11
xp_wannabe
xp_wannabe's Avatar
thanks very much, not sure how I missed that in my search...
Old 05-08-2010, 10:15 PM   #12
fourl6
AU Falcon Man
fourl6's Avatar
This was my exact problem... was causing the rear drivers footwell to fill up...
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2011, 07:11 PM   #13
kensim
Default Re: My firewall is leaking but not through the clutch cable...
good post craig au i got the same problem
kensim is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2011, 09:53 AM   #14
Cadge
Yeah i had the same problem as well... was like "no way, that wont fix my issue" when i saw that thread... was very humbled when it did...
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2011, 05:39 PM   #15
cedric
fixed mine too
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2013, 03:51 PM   #16
jdrooke14
XR6VCT
found it when wasing the falcon.....and after a huge smashing of rain filled up the rear footwell......this works great and happy to have a fix!
jdrooke14 is offline   Reply With Quote Multi-Quote with this Post
