Old 06-08-2010, 12:17 AM   #1
amiers
Default Odd steering problem
i have noticed recently that i have about a mil or two freeplay in the steering wheel, i thought it was the uni joint to rack or maybe the rack itself. however i have now noticed that after about 10 min driving the free play goes away, i mean if i move the wheel the slightest bit i can feel it move the wheels. where as in the first 10 min i can feel nothing a mil either way.
thoughts?
2018 Mustang GT
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 01:38 AM   #2
mik
mik's Avatar
maybe once the rack warms up the metal expands takeing the clearance away from the problem area, 1 mm is`nt very much, if it was mine and i was worried about it, i would probably try the adjustment on the back of the rack, theres a lock nut and hex head if i remember correctly, it just holds the rack rod against the pinion, i put a texta mark on mine for a reference so if i do it too tight and it starts to bind i can put it back the way it was.
Old 06-08-2010, 01:30 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
There was a steering rack recall for the AU some years ago. Could this be related? Did yours get done? I believed they welded something on the rack.
Old 06-08-2010, 04:00 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
the rack recall was just for the bolts that tie the rack to the crossmember, just every time you do an oilchange swing off the bolts, you'll be fine.
the ford fix was to put a dab of weld on the end of the thread so the rack didn't completely fall off. hopeless, i know.
Old 06-08-2010, 07:31 PM   #5
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
The steering shafts used to go on the cabs at about 300000km
Check the uni joints
Option 2 is tighten the adjuster nut a bit
Option 3 is stuffed tie rods
Option 4 is stuffed rack
At 10 years old it is probably a combination of all of them
Jastel is offline   Reply With Quote Multi-Quote with this Post
