Old 19-11-2010, 07:16 AM   #1
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Default BEM Replacement
Has anybody replaced the BEM on their AU? Do I have to got through Ford or is aftermarket ok? Anyone know what they are worth?
Thanks
-Craig
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 09:23 AM   #2
frd906
Just head to the wreckers, and get one,
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 09:29 AM   #3
fat4D
Although I think that you will need to go to ford to get it programed for your car? Or is it different to the ba's
Now Ford-less
But good things are coming in 6 months
fat4D is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 10:46 AM   #4
superroo
You can't stop the signal
superroo's Avatar
You can pick on up second hand, but you will need to go to ford to have it reprogrammed to suit (they are coded to the ecu).
It doesn't cost much to have it done, but the only point is the car won't start till it is done.
Old 19-11-2010, 11:24 AM   #5
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
if you dont want to tow your AU3 XR8 to the local ford dealer after installing the new BEM/BCM, drive to your closest ford dealer first, park where they can get to it, then remove the old BCM, put the new one in (there is a screw at the bottom of the dash where it's held in), then get them to program it.... to replace it, i can do it in an EL and AU in 4 mins max... its too easy..
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 11:36 AM   #6
T3man
T3man's Avatar
yep - that's the way to do it.
Aftermarket BEM????? Heheheh, good luck with that! New from Ford ... or take you chance with one from the wreckers.
Old 19-11-2010, 06:46 PM   #7
crakrz
T3 TE50 Blueprint
Thanks everyone for their advice, I will take it all onboard. I'm only about 1km from my local Ford dealership, so at least they are handy.
-Craig
Old 19-11-2010, 09:39 PM   #8
b2tf
not here much anymore
b2tf's Avatar
I believe you can actually get an aftermarket one - but it is actually a refurbished factory one. I have tracked down one for a VR Senator through work.
2024 F150 XLT
Old 21-11-2010, 06:22 PM   #9
T3man
T3man's Avatar
That's interesting that the Ford BEM will suit a Senator??????
Heheheheheheh
Old 21-11-2010, 07:12 PM   #10
b2tf
b2tf's Avatar
Heheheheheheh
Hey whatever gives you a laugh I spose.
2024 F150 XLT
Old 21-11-2010, 07:52 PM   #11
Beer Baron
There is a place on Moss st at Slacks Creek that rebuild them. Cant remember the name but i know where they are. They quoted me about $240 to fix mine but i haven't got around to doing it.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2010, 08:15 PM   #12
bartsau
bartsau's Avatar
I am pretty sure that you will find that injektonics do refurbished ones.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
