Old 15-01-2011, 10:43 AM   #1
sooty43
Default au1 fuel pump removal
What is the simplest way to replace a fuel pump in an au1 wagon. Do you drop the plastic tank or is there a round inspection opening in the floor?
sooty43 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2011, 12:57 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
when the fuel pump was replaced in the AU, the tank was dropped....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2011, 06:39 PM   #3
sooty43
Thought so,but when I ruined a pump 5 years ago I had to drop the lpg doughnut tank on to a tranny stand to move it 75mm sideways to unbolt the plastic fuel tank. Even on the hoist it is a **** of a job and takes a long time.It would be great if there was a removal cover in the floor above the tank and it would be a 5 minute job. 125mm hole cutter coming up methinks!
Old 15-01-2011, 06:43 PM   #4
XRGhia
meh.
XRGhia's Avatar
well it was done within 1hr max... and the AU has the regular petrol tank and a doughnut gas tank that goes exactly where the spare wheel use to go...
although having a hoist helps
Old 12-02-2011, 01:23 PM   #5
frostbite
Hi - I am looking to replace the fuel pump and sender unit in my AU2 Wagon, recently purchased, as gauge is giving problems - might as well do both at the same time - how did you go about getting the fuel pump out - did you end up cutting a hole in the floor ???
Any help appreciated - any description/photos etc would be most welcomed.
Many thanks -
Greg.
frostbite is offline   Reply With Quote Multi-Quote with this Post
