Old 06-02-2011, 08:06 PM   #1
Beer Baron
Default Speedo reading wrong.
Hey Hey,
Since converting my S2 AU SR to manual the speedo is way out at 100kph. When I'm doing 100kph on the dash i swear I'm doing nearly 120kph as I'm passing people pretty dam quick.
How can i check to see how far out it is ? I have 2 other cars but i don't trust the speedo on them as one of them is 41 years old and the other is a Daewoo that been around the clock.
Suggestions welcome.
Des
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2011, 08:10 PM   #2
TS50
TS50's Avatar
Do you have a sat nav?
or know someoen you can borrow one from
they have speed and acurate
2002 T3 Manual Naroma Blue TS-50 (049)Sunroof, Premium Sound, Black/Blue Leather Brembos
TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2011, 08:19 PM   #3
Beer Baron
AHHH good suggestion, I have a mate with a really good unit. Ok, so if its wrong how can i fix it ?
Use one of those speedo correcting units from shiftkits.com or change the diff ratio. I need a new LSD diff.
AU XLS.
Old 08-02-2011, 02:30 PM   #4
Beer Baron
What diff ratio do factory manuals have ?
AU XLS.
Old 08-02-2011, 02:40 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
Or a phone with GPS.
Or you could even be really silly and take it into a speedo place and get it fixed.
Old 08-02-2011, 05:13 PM   #6
hendoau99
app diesel mechanic
i would take it to a mechanic to have it checked out thoroughly. it's no good having a speedo that doesn't read correctly. you'll spen more time on the couch than in the car.
daily driver: au series 1.5 forte sedan
mods: clarion head unit, 15" alloys, ex police sump guard, futura grill,clear side flashers, AU s2 tailights,BA xr6 spoiler, kenwood 12" sub, kenwood 250W amp, kings sports lows, 2.5" lukey catback.
mods to come: rims!!
hendoau99 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2011, 05:32 PM   #7
Beer Baron
I'd rather do it myself. I could buy a speedo corrector box from shiftkits.com but i dont see the point when my diff is on the way out and i'll be fixing it soonish.
AU XLS.
Old 08-02-2011, 06:05 PM   #8
XC_Lizzard
If you are using standard factory options (gearbox, diff ratio, tyre diameter), then it should just be a matter of using the correct speedo drive gear/driven gear combination.
The speedo drive gear is internal to the gearbox, so you wouldn't really want to replace that, so it should just be a matter of identifying and sourcing the appropriate speedo driven gear.
XC_Lizzard is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2011, 06:09 PM   #9
Beer Baron
They are colour coded arnt they ?
AU XLS.
Old 08-02-2011, 09:45 PM   #10
SLO AU XR8
use the speedo gear from the auto!
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2011, 10:33 PM   #11
Beer Baron
Yeah im going to do that if it fits. I now know why its wrong though. The box came from and HP XR6.
AU XLS.
Old 08-02-2011, 11:03 PM   #12
SLO AU XR8
Have you got a 3.08 or 3.23 diff? The speedo gear will be for 3.45's
GT 335
11.3@124.1mph
383rwkw/513rwhp
Old 09-02-2011, 03:10 PM   #13
Beer Baron
3.23. The one in the manual is for 3.45. Im look at a 3.45 lsd now from ftg.
AU XLS.
Old 09-02-2011, 04:21 PM   #14
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
just swap out the speedo senders.. they should be the same (apart from the ratio, which is obvious), but the manual and auto ones are practically the same, just for diff ratios..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2011, 06:37 PM   #15
Beer Baron
Yeah im doing that for the time being but im still fitting the 3.45 lsd soonish.
AU XLS.
Old 09-02-2011, 07:01 PM   #16
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
take the car and run it on a dyno to check out you speed
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
